Old 06-25-2014, 10:42 PM   #1
buckaroo2's Avatar
charging two six volts
I recently bought a 2014 surveyor 275 sport i got them to put two six volt bats in now ouetion is can i charge these two bats in series at once on a 12 volt charger and if i do charger reads up at 8 and run foe a night down to 4 should the gauge on charger go down to zero to indicate a full charge this is an older charger im using and if its fully charged at 4 i do not want to over charge my bats as i see the water is bubbling a bit I thank all replys in advance
buckaroo2 is offline   Reply With Quote
Old 06-25-2014, 11:24 PM   #2
Batts-toy's Avatar
Two 6 volts in series will charge the same as one 12 volt and should be charged this way so they are equally charged. Make sure you keep the water level up to normal level, if your old charger normally goes to zero at full charge then it should do the same with the 6's, but it would be best to disconnect the charger, let the batteries set for a couple hours then test with a meter to determine full charge.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
