Old 07-18-2013, 03:58 PM   #1
Cold Shower
Please forgive me if I am being redundant. I posted a "new thread" yesterday and I haven't had any reponses nor can I find it. We have a 2013 Forest River, Surveyor Sport. And we can not get hot water either electric or gas. Please help otherwise I must wash dihees with cold water and take a cold shower!
Gensca is offline   Reply With Quote
Old 07-18-2013, 04:03 PM   #2
daydreaming about camping
jeeplj8's Avatar
typically if you do not get many responses it is because you are not giving the correct information. If you are not getting hot water from the hot water heater you need to let people know a little more, model of hot water heater, gas, electric or both? who set the unit up, was it winterized, etc.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 07-18-2013, 04:04 PM   #3
Campfire Master
The first thing that comes to mind is...are the bypass valves set right? If not, you probably have burnt out the electric element.
John
AVid is offline   Reply With Quote
Old 07-18-2013, 04:07 PM   #4
fonzie's Avatar
Do you know if water heater is heating water but still can't get hot water to faucets or water heater is just not working? If water heater is hot to touch, then make sure your water heater valves and by-pass valves are set to summer. Here is picture is you have 3 valve arrangement.
Fonzie
Old 07-18-2013, 04:46 PM   #5
TURBS's Avatar
That pic looks familiar
X2 what fonz says.
Also have you heard wh fire up on propane?
On electric can you hear the water sizzle?
Turbs
Old 07-18-2013, 04:50 PM   #6
fonzie's Avatar
X2 what fonz says.
Turbs
It should look familiar, it is yours. Why re-invent the wheel, I like to keep it simple.....thanks
Fonzie
Old 07-18-2013, 04:59 PM   #7
PPST OGCDG
Frank-VA's Avatar
If the hot water heater is working and all the tank valves are in correct position and you are still not getting hot water. Check your outside shower to see if both valves are cut off and not cut off at the shower head. If the outside shower is cut of at the shower head and the valves are open then the water is by passing.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 07-18-2013, 05:00 PM   #8
Herk7769's Avatar
Another thing to check (and often forgotten) is the outside and inside shower wands. If the valves are open and the water shut off at the wand, cold water can cross over to the hot side when hot water is demanded by any source.
HAM CALLSIGN - KC3FFW
Old 07-18-2013, 05:00 PM   #9
Herk7769's Avatar
Tag Frank. Like minds and all...
Old 07-18-2013, 05:05 PM   #10
TURBS's Avatar
I keep forgeting this........
