Old 03-10-2019, 10:23 AM   #1
Coupler height
Does anyone know the height of a coupler on a 287bhss? I need to adjust my hitch but my trailer is not at my house. Thank you
billydan91 is offline   Reply With Quote
Old 03-12-2019, 05:37 PM   #2
Hitch height
Mineís about 20Ē... using an equal-I-zer..
RRGuy55 is offline   Reply With Quote
Old 03-12-2019, 05:41 PM   #3
I think it is measured by leveling the trailer, measure the rear of the frame and front of the frame to pavement. When frame measurements are equal, then measure the coupler height. 18-20" sounds about right
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 03-12-2019, 11:19 PM   #4
Yeah the trailer has to be on level ground and then you measure the coupler height. I need to adjust my hitch drop because I recently lifted my truck but my trailer is not parked on level ground at the moment. I do not want to pull it out until I’m going camping in a few weeks lol.
Old 03-12-2019, 11:22 PM   #5
dannyabear's Avatar
There is a lot more to adjusting a WDH than just the height of the ball
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 03-13-2019, 12:58 AM   #6
Yes but that's the first thing you need.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 03-13-2019, 07:46 AM   #7
I know but thatís the first thing you start off with. I tried to just adjust the head tilt but that didnít give me enough to drop. My truck sits about two and half inches higher now. I donít want to guess so I need the exact measurement. I need to drop the brackets that hold my spring bars also. Iím using a husky cl.
Old 03-13-2019, 12:15 PM   #8
clarkbre's Avatar
Originally Posted by billydan91 View Post
I need to drop the brackets that hold my spring bars also. I’m using a husky cl.
I use that same hitch and have had it on 2 different trucks with the same trailer.
Honestly, instead of monkeying too much with the hitch and perches, I'd just adjust the ball height down how ever much you lifted the rear of your truck. 3" lift up, makes for 3" ball drop. You get the idea.
Also, don't change the perches and all that right away. The head height does not affect the spring bar tension. If it was dialed in on your truck before the lift and you leave the same # of washers in, it will provide the same tension regardless of ball height.
The real difference in how your truck sits is that it may be a bit nose high if your truck had the stock rake but now is lifted level. The front will appear to be high because the rear comes down a bit; however, it's the lift/level, not that your hitch isn't working properly.
If I recall correctly, from the bottom of the trailer coupler to the ground was 19 1/2". I set the bottom of the ball to 20" with 3 washers and the perches were set right in their center setting. Truck rides great.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 03-13-2019, 01:25 PM   #9
Yeah I get what your saying. I thought about just dropping the ball height how ever much it’s lifted but I haven’t messed with it since I got the trailer. now with more weight I want to start over and adjust everything.
Old 03-13-2019, 02:05 PM   #10
Measure from the true frame rail height. Take your measurement from frame to ground at the axle point or centered between two axles.
MtBiker is offline   Reply With Quote
