Originally Posted by doulos
I have the same problem as the OP and I was planning on installing a cigarette lighter plug next to the bed connected to my dual batteries. I was going to suggest this to the OP but did I understand that even with no humidifier, the CPAP will drain the batteries in just one night?
It should not. I ran my S8 last year in my RV no humidifier (on the PSW inverter) but with one group 24 AGM battery, all night and still had 75% reserve capacity in the battery and that is with the fridge running and an ocassional light on so no, should not be an issue with on humidifier at all.
Keep in mind I had more draw all night than just the cpap machine.
I have a pair now so even the humidifier shouldn't be an issue.
M y fridge has cooling fans that run when it's thermostat is calling for cooling as well.
Myself, I'm more comfortable running my CPAP on a 110 volt inverter than straight 12 volt battery power in the RV, but thats just my preference and nothing else.
