Originally Posted by fiwelsh
Going camping in PA this weekend can we hook up to city water for cooking,showering and dishwashing. We will be using the hot water heater but i don't want to clean the holding tank of antifreeze we still might have some freezing temps yet.What has to be done with the water filter to be placed into service.
If you hook up to city water for the things you mentioned flush good before using - but then your rig will not be winterized. What did you mean when you said holding tank of antifreeze - normally fresh water tanks are drained & no antifreeze put in them. Water filter will need a new filter element installed which should be removed before adding antifreeze to the system.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
