Old 05-27-2017, 11:20 AM   #1
gam
Dewinterizing sv230
Trying to drain antifreeze and the whole hose is turning, is this normal? I don't want to disconnect the hose up inside the TT
gam is offline   Reply With Quote
Old 05-27-2017, 11:59 AM   #2
bob213's Avatar
Where are you trying to drain the anti freeze from? I believe most of us just flush it thru the system with fresh water.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 05-27-2017, 12:52 PM   #3
gam
Thanks for taking time to answer! I am trying to drain the fresh water tank from the hose between the axles, per utube bodeos
Old 05-27-2017, 08:26 PM   #4
bob213's Avatar
This is a picture of low point drains. Your fresh water should be similar but more than likely only one and white. Hold the fitting with a wrench or pliers and use another wrench or pliers to twist off cap. If there is no cap then you probably have a valve located somewhere else.
Are you sure there is anti-freeze in the fresh water tank? Most people don't due to the after taste. Good idea to sanitize though.
Good luck
winter
