Old 08-26-2016, 09:45 AM   #11
Originally Posted by Barry1 View Post
Thanks Scott, for quick reply. My battery is only 1 1/2 years old, but I just checked the led light indicator board inside the TT and it indicates that my battery is fully charged. I also checked battery fluid and it is full.No corrosion on terminals. Will look into my converter fan as posted by Bama Rambler...thanks again.
My old TH did that and it was consistently occurring when the pump cycled on. Checked converter, battery, water pump, nearly everything. Then I realized that even though the ground cable looks fine, it was making a poor contact.
Turns out the ground cable from the battery was attached to the frame with a single self tapping screws.. no surface prep. So the only contact was the threads and eventually they had corroded.
Easy fix. Cleaned contact then covered with silicone.
Tom48 is offline   Reply With Quote
Old 08-27-2016, 08:03 PM   #12
Dimming lights in 2006 FR Surveyor
I Will definitley check my ground cable.
Barry1 is offline   Reply With Quote
210, light, surveyor
