Old 04-21-2014, 08:35 AM   #1
cnack72's Avatar
Draining the hot water heater
I got my first TT its a Surveyor sport 220. Should I drain the hot water heater after every time I use it and I am getting it ready for the first camping outing looking for any tips.
cnack72 is offline   Reply With Quote
Old 04-21-2014, 08:46 AM   #2
Make SURE the 110v switch is in the OFF position first. If you are going to leave it over about a week, I would drain it by removing the anode. Also, make sure the water pump is turned off and pull the pressure relief valve to release the pressure, otherwise you will get to chase the anode. lol
Old 04-21-2014, 09:10 AM   #3
mjones12's Avatar
Check the Surveyor forum for any tips you might need on the SP 220. A number of us have the 220, and there have been quite a few helpful posts.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 04-21-2014, 09:10 AM   #4
Herk7769's Avatar
Always use the anode/drain plug to drain the water heater. Using the low point drains to drain the water heater will suck bits of anode rod and calcium nodules into your cold water pipe (lowest pipe connection).
Once there, restoring water pressure will shoot that stuff into your faucet valves and toilet flush valve.
Name:	Camper Bidet 024.jpg
ID:	50545   Click image for larger version
Name:	Camper Bidet 025.jpg
HAM CALLSIGN - KC3FFW
Old 04-21-2014, 09:16 AM   #5
SKnight's Avatar
Opinions vary, I only ever drained mine to winterize.
If you do, first make sure the system pressure is relieved. You can open any faucet and leave it open until it quits. I then close that faucet, go outside and loosen the anode, stand to the side and finish taking it out by hand. Once out open the safety pop off valve to let it breathe. That will deluge it and flush any bits of anode out and will keep your safety valve free and moving.
Old 04-21-2014, 09:23 AM   #6
Herk7769's Avatar
The only thing I will add is to close your winterization valves before you drain it to keep crap out of the lines as it drains (glugs).
Old 04-21-2014, 09:29 AM   #7
Or save a step and just pull the relief valve on the wh and let the pressure off there. The glugging will also remove some of the junk in the bottom of the tank.
Old 04-21-2014, 09:59 AM   #8
TURBS's Avatar
I would not recommend using the hot water tap to expel the air from the wh tank.
It's possible especially during the summerization process that you forgot to un bypass the wh and then when you use hot water tap you'll still get water giving the appearance that your wh is full when in fact it's empty.
The relief valve is the only proper way to get the air out and to double check that the wh full before turning on.
TURBS
Sabre owners united!
Old 04-21-2014, 10:02 AM   #9
SKnight's Avatar
The reason I open a faucet is to prevent the anode shooting out under force.
Old 04-21-2014, 10:11 AM   #10
Flipping the relief valve lever will do the same thing + giving you the opportunity to make sure the 110v switch is turned to the off position.
drain, heater, hot water, water, water heater
