Old 04-03-2013, 04:09 PM   #11
wmtire's Avatar
I had to find where this was saved, but here is another forum post that may explain your converter better:
Now, letís talk briefly about what your RV converter does. When you plug your RV into an electrical source, or when you use the onboard generator, the converters job is to reduce 120 volts AC down to 12 volt DC to supply power to all of the 12 volt appliances and accessories in the RV. If you werenít plugged into an electrical source your RV battery(s) would supply the power to all of the 12 volt appliances and accessories in the RV. The converter basically prevents your RV battery(s) from draining when youíre plugged in.
There are two types of amperage draw concerning your RV. The AC amps we are using and the DC amps we are using. Iíll try to explain. When you plug your RV into an electrical source and use 120 volt appliances like the roof air conditioner, the microwave and a TV you are drawing amps from the available supply at the campground, usually 30 or 50 depending on your RV electrical system and the electrical supply you are plugged into. When youíre plugged into an electrical source and you use DC appliances and accessories like fans, lights, pumps or the TV antenna booster you are drawing amps from the converter. Are you more confused now than when we started? Letís try wording this a little different.
Letís say you plug your RV into a 30 amp electrical supply and you only use 120 volt appliances. Youíre using available amps from the 30 amp electrical supply for whatever 120 volt appliances are running, but the converter is drawing almost 0 amps because youíre not using any DC accessories. It will use a small amount for items like the LP gas leak detector, clocks or maybe an aisle light, but not enough to really affect the amperage you are plugged into.
Your RV converter is rated for a certain amperage i.e. 30 amps, 45 amps, 55 amps. In other words a 45 amp converter is capable of running 45 amps worth of 12 volt appliances in the RV. When your RV converter is working at its maximum capacity, which in this case is producing 45 amps for 12 volt appliances and accessories, it is drawing a full 8 amps AC out of the 30 amps available from the campground electrical supply.
Letís say you're plugged in and you're using a couple of 12 volt overhead lights (2 amps) and a ceiling fan (4 amps). In this case your converter is drawing very little from the camp grounds 30 amp electrical supply. In another scenario let's say youíre using a lot of 12 volt overhead lights (8 amps), you're running the furnace fan (11 amps), water pump (4 amps), TV antenna booster (8 amps) range hood fan (2.5 amps), and the battery is being charged by the converter charger (3 amps). Now, when the converter is running close to its full capacity it draws the full 8 amps from the campgrounds 30 amps, leaving you with 22 amps for other 120 volt appliances and accessories. As you can see it's unlikely that all of this would be happening at one time. The bottom line is the converter amperage draw will fluctuate depending on the 12 volt demand placed on it.
Another question I was asked was; I know my converter is also a battery charger so why wonít it bring my discharged batteries back to a full charge? RV converters do provide a charge to your RV house batteries, but only a small portion of the converters amperage rating is used for this. Normally 3 to 5 amps, which are not nearly enough to charge batteries that are discharged.
The converter battery charger is designed to keep the house batteries topped off with this trickle charge. Another problem with older RV converters is they charge at a fixed voltage in the range of 13.5 volts. If your batteries are fully charged this can be too much for a float charge and over time it will deplete the water level in the batteries cells. This is why itís important to check the water level in your batteries on a regular basis, especially when you leave the RV plugged in for extended periods of time. You need a three stage charger that can provide a bulk charge then an absorption charge and finally a float charge. Newer RV converters on the market are capable of charging the batteries this way.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-03-2013, 04:18 PM   #12
realebill's Avatar
Originally Posted by rmdrifter View Post
SP 186 2009, battery one year old. Battery was fully charged before we left, and charged whole 600 miles to AZ. We were on shore power the whole trip, or driving. Thanks for your insights, and I will replace the breaker.
When you indicate the "converter under load", what exactly does that mean? I ask because the noise sure sounded like the one you reference above. And to clarify, only one breaker switch tripped, not both.
converter "under load" would be with a lot of 12Vt items turned
on......my converter will squeal a bit if a lot of lights are on,especially when the 4 vanity lights are turned on . its actually the cooling fan on the converter that is making the noise in my trailer.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 04-03-2013, 04:29 PM   #13
TURBS's Avatar
If you have a wfco converter most likely that fan is about to quit as its common with wfco converters.
It should not squeal.
If the fan dies your converter will overheat and soon die thereafter.
Turbs
Old 04-03-2013, 04:46 PM   #14
Broadway Joe's Avatar
He stated "When it tripped, the lights slowly dimmed until they went out--connected to shore power at the time--and this dimming was accompanied by a high pitched whining noise (no, not me or my wife)."
This would indicate that it is not the fan.
Broadway Joe is offline   Reply With Quote
Old 04-03-2013, 04:51 PM   #15
The first thing to do is load-test the battery.
If it is faulty, it may be drawing a lot of power, and might cause the breaker to trip.
bakken is offline   Reply With Quote
Old 04-03-2013, 05:09 PM   #16
Thanks all for the responses--I appreciate it. I have since googled other forum discussions on this very topic, and "dimming lights" is not uncommon. RV electricity is fairly complicated. I will replace the breaker and hopefully the converter is not going bad as well. Another possible explanation from what I read is a surge in the line, but I didn't hear other campers mention it, and I think I would have heard if they had the same breaker thrown.
One of the comments above does bring up another question: Can I charge my battery by plugging into my 110 outlet at home before taking off on another trip, or is this method of recharging not advisable?
rmdrifter is offline   Reply With Quote
Old 04-03-2013, 05:41 PM   #17
I Leave my trailer plugged in all the time when home. You should monitor the voltage to not cook your battery and check the water level.
Old 04-03-2013, 08:30 PM   #18
wmtire's Avatar
It's not as bad as it may seem at first. Once you get the basics down, it's fairly straightforward. Here is a flow chart taken from RV Electrical Systems that may help you understand the cycle better. This chart even shows the optional surge guard (which is such a good idea to have, if you don't already)
Old 04-04-2013, 10:08 AM   #19
If your battery is old, it may also have several cells that are out and they may be overloading the converter, hence popping the breaker. So you might want to check the battery and see how it is doing.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 04-05-2013, 02:03 PM   #20
Thanks for the helpful responses. WM Tire, the web link you provided was very informative and useful.
Hopefully this is my final question on this topic: How do I replace the circuit breaker? It seems as if it just pops out somehow, but I don't want to force anything and cause damage. I looked for a youtube of a replacement but could not find one. Thanks.
