Old 08-13-2013, 08:37 PM   #1
Entertainment center remote...
What is everyone doing about the remote to the entertainment center while in bed...
It's pretty tough to run the DVD while in bed...
Any mods out there to get that signal around the corner without getting out of bed...
If I hang off the side of the bed with arm stretched out it kinda works...
SP220
Steve & Brigitte
North Eastern Oregon
The Right Side of the State...
_______________________
2013 Surveyor Sport SP220
2014 Toyota Tundra Dbl
samsberr is offline   Reply With Quote
Old 08-13-2013, 09:05 PM   #2
Batts-toy's Avatar
I guess it depends on what type entertainment center you have but mine is in the center of the room and has a swing around Tv which faces the living area or can pivot to face the bed. I had the same remote issue because the DVD player or satelite receiver was on the other side of the wall below the Tv, so I measured it up and cut a hole in the paneling, framed it like it belongs there and now I turn the receiver or DVD box and stick the front through the hole when watching from bed.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 08-14-2013, 01:12 PM   #3
Thanks for the idea...but i do have the flip around TV but the dvd/radio is a flush mount system and ya cant just turn it around without tearing it out first...
How are other folks dealing with it???
Steve & Brigitte
Old 08-14-2013, 01:24 PM   #4
mjones12's Avatar
I have the same unit as you, and I can't figure out a way to do it, either. All I can figure is to get up and go around to the other side when you need to start or stop the movie. A PIA, for sure.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 08-14-2013, 01:29 PM   #5
Yea not very well thought out...
If I'm laying on the starboard side of the bed with the mirrored pantry door on the slideout open then reach out almost to the window i can get it to work most of the time...They forgot to put that in the directions...
Steve & Brigitte
Old 08-14-2013, 01:41 PM   #6
firephighter's Avatar
Samsberr is on the solution. You will need to strategically hang a mirror on the opposing wall from the player. From which you will be able to send the remote signal to the unit.
Jason and Angeleck
2007 301 BHD
1999 2500 Suburban 454
firephighter is offline   Reply With Quote
Old 08-14-2013, 01:45 PM   #7
You could try an IR remote controll repeater/extender. It basically recieves your IR remote signal locally, transmits it over RF frequencies to the repeater which converts it back to an IR signal close to the DVD/TV. Cost is approx $25 from radio shack. It does add some clutter, and requires to be plugged in. So it depends on how badly you need it.
Personally, I'd stick with the mirror trick if that works for you
SCOC is offline   Reply With Quote
Old 08-14-2013, 02:09 PM   #8
mjones12's Avatar
Yeah, good idea bouncing it off the pantry mirror. I didn't know if that would work or not. Good thinking.
Old 08-14-2013, 02:10 PM   #9
Missing Link
cyclepuck's Avatar
Extendable golf ball retriever, mirror, some kind of 90. Or eliminate 90 and use just mirror with remote.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 08-14-2013, 04:00 PM   #10
What a great forum...spitballin and twistin ideas allover...
Wont leave home without ya...
Thanks...
Steve & Brigitte
