10-31-2013, 07:22 PM
F150
ok how many are pulling their 5th wheel with the F150 crew cab short bed eco boost truck .
don't be hating
1 Surveyor
2015 Silverado Duramax w/Allison transmission
2014 surveyor 293RL fifth wheel
10-31-2013, 07:35 PM
All you need is a high enough payload rating on the truck to handle the weight of the hitch, all people and gear you travel with and the loaded pin weight.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
10-31-2013, 08:05 PM
I know two people who does it but one has a long bed and HD package and ecoboost, and the other one is a short bed 5.4 I believe ...
The numbers have to work ...
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
10-31-2013, 08:17 PM
I haul my 5'r with my Ecobeast, but it is a longbox. First and foremost run the numbers on your proposed combo. There are VERY few pairs that will work.
What's your payload from your door jam sticker.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
11-15-2013, 09:57 AM
Just have to find out the gvwr. Gross vehicle weight rating.Should be a sticker on your door of the ford. Includes all weight in the truck. Passengers, fuel, cargo, hitch weight etc. The gcwr ( gross combined weight rating is all that plus the trailer. The new f-150 should be able to tow your trailer pretty easily according to ford. I tow mine with a gm so I'm not sure but I heard the f150 had a 9000 lb. Tow capacity.
11-15-2013, 10:08 AM
Cargo carrying capacity is the first number that you'll need to decide if your within limits.
You'll normally exceed this number before ANY OTHER weight.
This number will be found on your tire info sticker on your door jamb.
11-15-2013, 10:13 AM
Shown here above the tire info. "2448"
This number is.
All passengers
All items carried in the truck and bed
Hitch and sway system for hitch pull.
A 1/2 ton will exceed this number first.
11-28-2013, 06:08 PM
here is the picture of our new 5th wheel
1 Surveyor
11-28-2013, 06:28 PM
That trailer lists a 1792 lb pin weight dry....
11-28-2013, 06:46 PM
Always Learning
Congrats! That's a pretty pretty camper.
11-29-2013, 12:49 AM
It is good looking.
11-29-2013, 08:30 AM
Thanks everyone , i have heard some say i need a bigger TV and i have had bigger, i've had an 06 F250 6.0 diesel , and a 2010 F350 V10 , and hands down the F150 Eco Boost tows better than either one of those .
1 Surveyor
11-29-2013, 09:31 AM
Hi neighbor. Great looking 5er. Can't wait till spring. I find half the fun of getting away is the time behind the wheel.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
11-29-2013, 09:52 AM
Hi back at you neighbor , i see you are a golfer and i work at the golf course in Savanna , have you played it ?
1 Surveyor
11-29-2013, 11:18 AM
I've heard those things pull great, in fact I might (as much as I'm not a Ford guy) go that direction next year or so. I'm not a REAL strict weight guy, but I'm pretty sure you've busted your payload without putting a single thing in the truck. Not enough that I'd worry about axle / bearing / suspension wear overly much, but I'd be most concerned about exceeding the tire rating in your case. Manufacturers tend to put "just enough" of everything on a vehicle. You might think about going to something other than stock tires for that load if you haven't...it would suck to loose one with 9000 lbs. behind you and nearly 2000 lbs. pushing down on them.
11-29-2013, 11:36 AM
Yep 10 ply tires going on in the spring
1 Surveyor
11-29-2013, 01:40 PM
Surveyor, I sent you a PM.
Rudy and Jenny
