Old 09-12-2019, 05:54 PM   #1
clarkbre's Avatar
Fixed fresh water drip
Since we bought our trailer the fresh tank drain has always felt somewhat loose and constantly dripped. Knowing that FR uses clamp systems instead of hose clamps, I thought we could just live with it. It got worse over the summer so today I decided to pull back the foam and see if I could fix it. To my surprise, the blue hose was clamped tightly to the fitting and it was the fitting that had been leaking. From the factory, it had only been hand tight and while unscrewing the drain cap, had continued to loosen and leak more. So, a few wraps of teflon tape and screwing it in snug (but carefully) with an adjustable wrench, we are leak free! I love these low cost fixes....just wish I had the ambition to tackle them sooner!
ID:	214790Click image for larger version
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 09-12-2019, 05:57 PM   #2
Fulltime family RVer
So the act of opening the low point drain will always try to loosen the fitting?
Maybe consider putting a quarter turn valve to into the cap's place.
Old 09-12-2019, 07:21 PM   #3
clarkbre's Avatar
No.
I'm showing the recognition of a half-assed effort in finger tightening from the factory, covering it with foam and what I did to fix it. Now that the main tube is tight to the fresh water tank, the drain plug will lossen without spinning the main tube.
The quarter turn idea is a good one though. Got a part # or website link for one? I would put them on the low point drains as well.
fresh water, water
