Old 03-06-2018, 03:17 PM   #1
JAXCMC's Avatar
Flat tire ramp
Brand new owner of a 2018 Surveyor 200MBLE. I just updated from a 2008 Niagara pop up soooooo, I was looking at the flat tire ramps for when (hopefully not) a flat occurs. But I read that they do not work well with leaf spring type tandem wheels which the 200MBLE has. I don't see a really good place to put a bottle jack. Was just wondering what everyone uses. Thanks in advance
JAXCMC is offline   Reply With Quote
Old 03-06-2018, 03:33 PM   #2
SeaDog's Avatar
I carry a bottle jack. Something I thought about is if your trailer is at or near max weight and you have a tire going low so you run the good up on a ramp you have now subjected the good tire to an over weight condition. This is just my thinking may be right may be wrong in either case I will stick to the bottle jack and some boards.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-06-2018, 03:36 PM   #3
mmangiarelli's Avatar
Our TT had wide spread axles and leaf springs. We fabricated a ramp out PT 2x10s on edge to acheive clearance height needed for tire changing.
2015 Tracer 3140RSD Touring
2016 Nissan Titan XD Diesel
Blue Ox Swaypro BXW1500
mmangiarelli is offline   Reply With Quote
Old 03-06-2018, 09:37 PM   #4
clarkbre's Avatar
Check to see if your trailer has the Equa Flex Suspension as an option (Yellow leaf spring hanger between the tires). If so, you likely can't use a ramp as the suspension will have quite a bit of flex and not allow a tire to come off the ground.
Regardless, a bottle or scissor jack directly under the axle, close to the flat tire will be sufficient. For added protection, set the parking brake on the tow vehicle and potentially set up blocks and temporarily lower the stabilizer jacks on the flat tire's side.
Also, with safety in mind, get a high vis construction vest and warning devices for changing a tire. The side of a 60mph road is no place to find out what you really need.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 03-07-2018, 08:45 AM   #5
JAXCMC's Avatar
Thanks everyone!!!!
Old 03-07-2018, 09:16 AM   #6
Don't lift your trailer with any kind of jack under the axle. Use a bottle jack on the frame between the axles.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 03-07-2018, 09:54 AM   #7
clarkbre's Avatar
Just out of curiosity, why?
Doesn't the weight of the trailer ride on the axles?
Are they so fragile that they will crush if you jack right at the spring perch?
If you took it to a tire shop, where would they lift it from?
Old 03-07-2018, 10:03 AM   #8
You run the risk of crushing the axle tube. You could try and fabricate a cradle to axle diameter.
Old 03-07-2018, 10:04 AM   #9
Just out of curiosity but why?
Yep, it does. But from a strength standpoint, using a jack which has a very small area of contact under an axle would pose more risk of damage to the axle than utilizing the frame which has little to no risk.
Any tire shop that is familiar with RV construction will know to not lift a trailer by the axle with a jack.
And actually, it is much easier to position a bottle jack between the axles on a frame member than positioning under an axle.
As always, your choice.
2016 Microlite 21DS
Blue Ox SwayPro
Old 03-07-2018, 10:08 AM   #10
SeaDog's Avatar
A tire company should know better then place a jack on the actual axle away from the spring attachment or in the case of torsion axle away from the solid attachment point. Jacking on the axle itself has a chance of bending it.
Retired Navy
tire
