Old 10-05-2016, 02:41 PM   #1
Renderspud's Avatar
Front Cap Oxidation Issues
Last September we purchased a brand new 2016 Surveryor 240RBS. After some initial problems we were finally able to get it out on the road and put it through it's paces.
In spite of the initial issues and a few more that have popped up after a full summer of use, we love the trailer.
That being said, we are having a fairly serious cosmetic issue and I am curious if others have had this problem or if we just 'got lucky'? Over the summer the end cap has oxidized horribly.
I've been in touch with FR Warranty and they are working with me to repair the front cap. I initially thought that it would be 'painted' but talking with my service rep, he said they will most likely replace the front cap. He said the front cap manufacturer had messed up and applied some faulty gel coats on some caps.
Has anyone else had this happen? I'm attaching a pic. Remember, this is a 2016 model.
Renderspud is offline   Reply With Quote
Old 10-07-2016, 10:36 PM   #2
Same issue on a 2015 251RKS
My front cap is heavily oxidized. It looked almost identical to your picture.
A detail shop used a high speed buffer but while it looks better it is still not right.
BurkF is offline   Reply With Quote
Old 10-07-2016, 10:47 PM   #3
I have a 2015 and it is still shiny and looks new. It should be replaced, especially since is new.
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days; 2019: 8 days (so far)
elchilero53 is offline   Reply With Quote
Old 10-08-2016, 11:58 AM   #4
When we ordered our 251 it came in with the new white retro colors. FR said they changed because of the issues with the brown gel cap fading and oxidizing.
SCtravler is offline   Reply With Quote
Old 10-09-2016, 12:10 PM   #5
Last year our new2015 model didn't have it that bad but had small areas on the front, side and back. Dealer got it repainted last winter and no troubles this year.
sakool is offline   Reply With Quote
Old 10-09-2016, 12:11 PM   #6
There are quite a few threads on this issue and it is not limited to Forest River either. I have a 2014 Prime Time(which is FR) and between June and September of this year, I got the same issue. I have called Prime Time and because it is out of warranty, they will not address it. I kept the unit waxed, Aero 303, etc numerous times a year. It is a defect with the cap and gel coat. Painting will correct it for a while. Hope you get a new cap.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
johnruff is offline   Reply With Quote
Old 10-09-2016, 12:24 PM   #7
Oxidation issues
Check out restoration products intended for the marine market and environment. Having said that, nothing is really going to remedy an inferior gel coat. And that's what the RV industry gives us.
slipf18 is offline   Reply With Quote
Old 10-09-2016, 12:37 PM   #8
Fiber cap oxidation
I have a 2013 RLSA 34 Cedar Creek 5th wheel and we had the same problem . FR agreed to replace the caps , so in September this year we took our unit to Topeka Indiana and they replaced both the front and back caps in about 6 Hours ! Looks like brand new again . Hats off to FR for standing behind there product ..
greenroads is offline   Reply With Quote
Old 10-09-2016, 12:45 PM   #9
Front Caps
We own a 2015 Salem Cruise Lite that had both upper and lower front panels replaced within the last 5 months due to peeling paint/coating. Both were done without costs to us. The underlying metal didn't seem to have been primed before the outer coating was applied. Also, this happened after traveling thru very heavy rain. The coating seemed to have turned to putty similar to paint after stripper was applied. It hardened again after the rain/water had dried. Weird!!
gfarmcafe is offline   Reply With Quote
Old 10-09-2016, 01:27 PM   #10
I just had mine replaced by Primetime under warranty did it
colo native is offline   Reply With Quote
Old 10-09-2016, 07:29 PM   #11
Enjoying Life
We had our 2015 Crusader 295 RST develop the same appearance issue. We sent pictures to our selling dealer who shared them with FR. The reply came back that Forest River would repaint, clear coat the front cap. It came back to us as shiny as a highly polished silver piece. My hat goes off to Forest River for standing behind their products. I know people bad mouth this particular manufacturer, but I can not endorse them strongly enough.
2003 Ford F250 6.0
Life is great, Beer is Good
mpoulin8 is offline   Reply With Quote
Old 10-09-2016, 07:36 PM   #12
We have to agree. It's a love/hate thing!
Old 10-10-2016, 04:20 AM   #13
DouglasReid's Avatar
All gelcoats will oxidize with time and usually the darker colors do so more quickly than white. The RV manufacturers are famous for using the cheapest materials available and sometimes they admit they screwed-up. If they will replace it, Id go that route BUT, it WILL happen again!
Buffing and polishing is one solution but it is a very temporary fix. We tried everything on our 2012 Wildcat Sterling. What we found that worked the best is Poli Glow. Get the 3 part kit that includes the Poli Ox, follow the instructions (it is very easy) and you will be set for a year when a single coat will bring it back to looking like new again.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 10-10-2016, 06:43 AM   #14
front cap
Yes I have a 2015 FR surveyor 240RBS as well love the trailer bought it in march 2016 mine has the same problem was told by dealer when i winterize it to bring it in dont know if it will be repainted or replaced
John
jec9017 is offline   Reply With Quote
Old 10-10-2016, 11:00 AM   #15
Radioman
This is interesting as I have a 2013 Silver Back. When I bought it, the dealer sold me Cilajet that is supposed to last 5 years. We bought the unit in Feb 2015 used. Today the front cap and drivers side and back end are heavily oxidized. I called on the Cilajet warranty and they say its covered. I'm wondering how far its going to be covered with what I've read here?
Radioman
2005 Ram 3500 4X4 Diesel
2013 Silverback
Yuba City, CA. 95993
bjlyons is offline   Reply With Quote
Old 11-05-2016, 12:20 AM   #16
No help
Was told my 2015 Surveyor 251RKS was out FR warranty and cap manufacturers warranty so there wasn't anything FR would do. If I sent pictures they would review the issue. I had just had a RV detailer buff and wax the cap before I found out about the manufacturer defect so pictures won't show the damage. I am pretty much screwed with a defective front cap that looks terrible and will kill my resale value. FR sucks and I will not buy another. I like my camper a lot and try to make it look good. Once the wax job wears off it will look like crap again.
Old 11-05-2016, 02:05 AM   #17
Witch Doctor's Avatar
Maybe you can still keep it looking like new. I tried that new look by rustoleum on my truck trim it was all faded gray, I was shocked how they look now they are like new. The product works not cheap, but go's a long way that could be your answer when it starts to oxy. again......They have a web site Newlook.com....
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-05-2016, 08:18 AM   #18
what was the date of manuf. of your PT unit?
4x4 Lariat
Old 11-05-2016, 08:35 AM   #19
KyDan's Avatar
I feel your pain but if you really mean that- why not get it painted and go
camping and try to love your rig again??
Deal with it and move on and
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 11-05-2016, 10:22 AM   #20
Painting the fade will last 3 - 5 years and then it will be back. So that being the case, I will spend those dollars when I am ready to get rid of it. In the mean time, I will spend the time each year to make it as good as possible.
4x4 Lariat
