Old 07-22-2012, 10:33 AM   #11
Snowman53's Avatar
Our step flexes a bit too. Perhaps I will add it to the items for a dealer warranty visit.
Snowman53
2011 Surveyor SP240, 1996 Coleman Sun Valley
2001 Suburban 1500, 3.73, K&N, Jet Chip, Magnaflow dual exhaust, Reese Dual Cam
Snowman53 is offline   Reply With Quote
Old 07-23-2012, 10:01 PM   #12
Ret E-9 Anchor-clanker
donanddona's Avatar
Try using auto screw jacks to limit movement.
donanddona is offline   Reply With Quote
Old 07-24-2012, 08:26 PM   #13
mattison09's Avatar
Originally Posted by Beausdog View Post
I had dry rot in my last trailer. It's not too bad to fix it. Let me know if you need any help and I can recommend what I use to fix mine
Beausdog if you could do this I would appreciate it. I have the same year and model as Ellisz. Although my steps are not flexing, I know I have dry rot flooring and will be fixing it after Labor Day. I am looking for what others have done. My linoleum is stained in a spot, pulled away and soft in others.
mattison09 is offline   Reply With Quote
Old 07-24-2012, 08:30 PM   #14
Easier to add angle iron braces from the bottom of the step frame to the trailer frame and you don't have extra jacks to store.
Old 07-24-2012, 09:22 PM   #15
No worries, mine was fairly easy. Of course the linolium had pulled away, so I cut it out (it was in my pack and play area 3 foot by 1 1/2 foot piece. Then had to dig a bit to see how bad it is and if it is in fact repairable. Most are repairable unless it seems to have spread and then its easier just to cut the wood out and replace it. Mine however had not.
So under this 3 foot long I could see the stained soft wood. Sand it down to get the grit and junk off the top layer. Then take an air blow machine (hair dryer works too or anything powerful enough) and blow off the saw dust and dead wood shavings.
I went to lowe's and got a wood repair kit. I believe it was made by elmur glue or something like that, but came in a kit. Basically follow those instructions, and spread it out on the wood (mainly the soft rotted parts). Takes 12 to 24 hours to work into the wood and dry. Then there is wood apoxy that comes with it. Follow the mix instructions and fill in the rotted holes. Another 12-24 hrs to let it harden.
Repeat sanding and clearing off the layers of dust with a air blower of sort.
Now the fun part, the linoleum. While I was at Lowe's, I found the same linoleum that was in my TT I had. However, with that being said, it had to be special ordered and I had to buy the WHOLE roll. As such, I found 1x1 linoleum tiles with adhesive backing that looked pretty close on hand at the store. I put those in there, looked good too, took some cutting and fitting under the boards but wasnt too bad.
Only issue was it didnt match, and you really couldnt tell unless you looked or knew what you were looking for. We all know these units are built with one roll of linoleum, so once you cut it, its never gonna be right again, and you cant replace it all without tons of labor.
My advice, if you plan on keeping your TT, then fix the wood and get the flooring you like if its not in the main area, otherwise try to match it for future trade in or sale purposes.
#1 issue with your rig is going to be, you can fix the issue all you want, but if you dont find the source of the damage, you will not win. Hope you know how the dry rot started and that should be your first repair to cease the entrance of water to the effected area.
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
Beausdog is offline   Reply With Quote
Old 07-25-2012, 04:45 PM   #16
MOD Guy's Avatar
Mine has a little flex, but not in the floor, just the step. You probably only have a single step, not the double setup. If you can feel the floor moving, then you very well may have some water damage. If so, it would be fairly easy to add a metal brace under the floor to reinforce it. You caould bolt directly thru the floor in the forward closet area and back under the galley cabinets. Hope the issue is not too bad.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 07-25-2012, 04:58 PM   #17
MtnGuy's Avatar
I use this to steady my steps: Self-Storing Step Save Stabilizer - Stromberg Carlson JSS-85 - Stabilizing Jacks - Camping World
Old 07-26-2012, 03:42 PM   #18
mattison09's Avatar
Beausdog thanks for the information. I found the Elmer's products at home depot. I cut out a square of the linoleum and this is what it's looks like underneath. The linoleum seems like its not attached to anything.
Old 07-26-2012, 03:47 PM   #19
Yup....looks like water damage, i would keep cutting out until you find good wood surrounding then repair. If its beyond repair, you can look at getting new wood in it
Old 07-26-2012, 03:50 PM   #20
Also looks like you have the exact same linoleum i had in my 2009 TT lol
