Old 10-31-2014, 09:58 PM   #1
Furnace blowing cold air
Does anyone know how to fix a furnace blowing cold air on a 2012 220rbs . Fan is on auto and the furnace turns off thinking it's warm but it is not
kmusselman is offline   Reply With Quote
Old 10-31-2014, 10:06 PM   #2
B and B's Avatar
Is the propane tank on, line bled with the stove to make sure no air in line?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-31-2014, 10:26 PM   #3
2007 WildCat 32QBBS
05CrewDually's Avatar
It's probably shutting down because it's not lighting. When you turn it on, the fan will come on. Shortly after you should hear audible clicks about 2 per second, then they'll stop. If it didn't light it will try it 2 more times. If it senses no fire in the burner, it shuts down everything.
Like above stated, make sure you have plenty of propane and purge out the air by running the stove and/or water heater. After trying it again and you still have issues, try it while the stove is lit on high. Watch the flame on the stove and see if it just about goes out or turns yellow. This is how I found out I had a faulty pressure regulator at the propane tank.
05CrewDually is offline   Reply With Quote
Old 10-31-2014, 10:37 PM   #4
Adony's Avatar
Identical Problem solved..
My furnace would run (fan) for about 3/5 minutes then shut off without emitting any heat... Immediately I suspected the worse..BUT.. the propane tank I believed to have propane in it was empty and the auto changeover valve wouldn't work as the second full tank was not turned on.. Opened valve on second tank and had plenty of heat...
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
furnace
