Old 05-28-2013, 01:08 PM   #21
TURBS's Avatar
Originally Posted by herk7769 View Post
I did this mod before the delay relay, it did not reduce the start up load near enough for my needs and the demand of the Coleman Mach 3 15K.
Delay module seem to have cured that?
Old 05-28-2013, 01:36 PM   #22
Herk7769's Avatar
Oh, yea. Start up drain dropped 10 amps.
HAM CALLSIGN - KC3FFW
Old 05-28-2013, 01:40 PM   #23
TURBS's Avatar
Very nice!
Old 05-28-2013, 02:35 PM   #24
wneise's Avatar
Yeah it is pricey, but I like the principle of how it works and I have heard of some of the kit relays burning out. I opened my Dometic unit up last year to find that the startup cap is an option that was not installed, so I thought to at least install the Dometic hard start kit. It works with my generator if its the only thing running at startup. I will try the fan delay here soon to get those extra couple of amps back.
wneise is offline   Reply With Quote
Old 05-28-2013, 03:15 PM   #25
Herk7769's Avatar
The advantage of the relay we selected is that it goes in the thermostat wiring and not the compressor line wiring (although by removing a jumper you could).
It just delays the "go" signal to the fan motor from 3 seconds to several minutes. Since the dial is so "course", I have it "almost" off and it is about 5 seconds by my watch.
Old 05-28-2013, 03:24 PM   #26
TURBS's Avatar
Mines about 8 seconds.
Old 05-28-2013, 03:27 PM   #27
Herk7769's Avatar
I can move it several seconds just by putting a screwdriver blade in the slot and think bad thoughts.
Old 05-28-2013, 03:29 PM   #28
TURBS's Avatar
Old 05-29-2013, 06:28 PM   #29
Hey guys,
I just installed the timer delay today that I got from Graingers. It seems when I turn it to the lowest delay, I get about 4 seconds. When I turn it a hair to make it delay a little longer, I get 32 seconds. I don't seem to get anything in between.
Do you guys think I should take it back and have Graingers swap it out. The a/c did start today on a Yamaha 2400is at near 90 degrees, so I think it did solve my problem. I was just wondering if I should have more like 5 or 6 seconds. Would 32 seconds be to long for the compressor to engage without a fan.
Thanks for all the great help!
Ponti
Pontihog is offline   Reply With Quote
Old 05-29-2013, 06:48 PM   #30
Herk7769's Avatar
Originally Posted by Pontihog View Post
Hey guys,
Ponti
That seems about right. A heartbeat past 4 seconds is all you need.
