Old 05-29-2013, 06:58 PM   #31
TURBS's Avatar
Originally Posted by Pontihog View Post
Hey guys,
I just installed the timer delay today that I got from Graingers. It seems when I turn it to the lowest delay, I get about 4 seconds. When I turn it a hair to make it delay a little longer, I get 32 seconds. I don't seem to get anything in between.
Do you guys think I should take it back and have Graingers swap it out. The a/c did start today on a Yamaha 2400is at near 90 degrees, so I think it did solve my problem. I was just wondering if I should have more like 5 or 6 seconds. Would 32 seconds be to long for the compressor to engage without a fan.
Thanks for all the great help!
Ponti
take a pocket screwdriver to adjust and you can get a little more precise .
ive got mine at about 8 seconds.
Old 05-29-2013, 07:17 PM   #32
Thanks again for all the great information. I will try it again tomorrow, but either way I think it solved my problem.
Ponti
Pontihog is offline   Reply With Quote
Old 05-29-2013, 07:48 PM   #33
TURBS's Avatar
Hey guys,
Ponti
Also when the compresser kicks on the compresser fan outside is running so 20-30 seconds should be no big deal to start inside blower fan.
Turbs
Old 05-29-2013, 08:05 PM   #34
Turbs
It's not the compressor fan. It's the condenser fan. If the evaporator freezes up inside (due to lack of airflow), there's nothing for that condenser fan to condense. I don't think I agree with your conclusion. At the least it needs more research.
Old 05-29-2013, 08:09 PM   #35
TURBS's Avatar
Do you think in 30 seconds it could freeze up?
And correct on the condenser fan as its what I meant.
I would think minutes would be closer to being an issue.
Old 05-29-2013, 08:17 PM   #36
wneise's Avatar
30 seconds may not be that much of a problem since the refrigerant starts absorbing heat already in the coil and fins of the evaporator. However, I thought that the fan motor was a dual shaft and blew both the condenser and evaporator coils.
wneise is offline   Reply With Quote
Old 05-30-2013, 03:25 AM   #37
Changing the starting capacitors in your A/C ???
Your trying to fix the effect, not cause. Your generator is not rated for the load your putting on it. Generators should run at max 75% of their rating.
Get a bigger generator.
jamesroadking is offline   Reply With Quote
Old 05-30-2013, 07:07 AM   #38
Herk7769's Avatar
Not all this has to do with generators.
This issue came to my attention when dealing with being at the end of a long 30 amp aluminum wire campground run on a hot July day. The low voltage under starting current load would stall my compressor.
Low voltage and air conditioning
HAM CALLSIGN - KC3FFW
Old 05-30-2013, 04:00 PM   #39
lswartz's Avatar
It finally got hot enough (91 degrees) to test my Yamaha 2400 generator on the TT's Coleman-Mach 13,500 AC. It seems to run OK for about 1 hour, including restarting the AC. The 30 amp to 15 amp adaptor gets a bit warm though. More than I would like. Is there any better solution than the 30 amp to 15 amp adaptor?
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 05-30-2013, 04:03 PM   #40
TURBS's Avatar
Lol bigger gennie with 30 amp outlet.
