Old 05-30-2013, 04:34 PM   #41
lswartz's Avatar
Originally Posted by f1100turbo View Post
Lol bigger gennie with 30 amp outlet.
May all your beer be hot .
This generator is about all I can lift into the bed of my truck & I am sure it gets worse with age. I almost bought a Champion with a 30 amp outlet (only produced 20 amps) but can't take the noise in the campgrounds that we use. It was a nice surprise that a hard start kit was not needed as the OP indicated.
Maybe I will share a cold one with you if you ever get out to the east coast.
Thanks.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 05-30-2013, 04:47 PM   #42
TURBS's Avatar
Thanks.
I am not sure theres much you can do other than what you are doing.
Make sure you have a good connection on the thirty amp plug as well as the 15 amp adapter.
Old 05-30-2013, 04:50 PM   #43
Herk7769's Avatar
Thanks.
Too true. I use a "deer lift" when I need to move my Yamaha EF30S out for maintenance. Too heavy for just me to get in and out of the truck bed without the mini-crane.
HAM CALLSIGN - KC3FFW
Old 05-30-2013, 04:56 PM   #44
wneise's Avatar
Its hot most likely because your pulling more than 15 amps through it which you should not. It looks like the receptacle on the Yamaha 2400 is a nema20. Try to get a 20 amp to 30 amp adapter. It's the one where one of the prongs is sideways.
wneise is offline   Reply With Quote
Old 05-30-2013, 04:56 PM   #45
TURBS's Avatar
use my "engine lift" to get mine in and out ...... lol but shes a monster !
Old 05-30-2013, 05:01 PM   #46
MtnGuy's Avatar
It finally got hot enough (91 degrees) to test my Yamaha 2400 generator on the TT's Coleman-Mach 13,500 AC. It seems to run OK for about 1 hour, including restarting the AC. The 30 amp to 15 amp adaptor gets a bit warm though. More than I would like. Is there any better solution than the 30 amp to 15 amp adaptor?
Hmmm.....I never felt the adapter cord on my EF2400is......maybe I should check that out.
Make sure that all other 120 volt loads are off, including the fridge which should be on gas only.
Old 05-30-2013, 05:02 PM   #47
TURBS's Avatar
And wh on gas as well !
Old 05-30-2013, 05:46 PM   #48
MtnGuy's Avatar
Yeah, that would be a biggie.
Old 05-30-2013, 06:00 PM   #49
acadianbob's Avatar
And especially the electric hot water . . .
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-30-2013, 06:00 PM   #50
acadianbob's Avatar
Sorry, missed your post . . .
