Old 10-20-2013, 06:21 PM   #1
robmac's Avatar
Heating Question
I have a heating register/grille , or i think its a heating register, in the bathroom on the tub surround wall. However when the furnace runs all the registers throw heat except this one. Is this register suppose to be for the heat? I have a surveyor sp260 TT just wondering if anyone else has this issue
2013 Surveyor Sport SP260
2004 F150 4X4 XLT Supercrew
robmac is offline   Reply With Quote
Old 10-20-2013, 06:47 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I think it's a air return vent that sucks air into the furnace. You should not feel air coming from it.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-20-2013, 08:50 PM   #3
robmac's Avatar
i will check that out next time i run the furnace and see if its sucking air in. Then i will know for sure if its the return grill.
Old 10-20-2013, 09:23 PM   #4
DDC
DDC's Avatar
I have a 264 and wondered about this too, so I took the grill off and it is a heating vent but the tube is just sitting there, I made an aluminium box and connecter the tube properly and it warms fine now.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 10-20-2013, 11:34 PM   #5
robmac's Avatar
Thanks for the reply DDC, It looks like i'll have to pull off the grill and check to see if there is anything behind there and run the furnace
Old 10-22-2013, 04:33 PM   #6
schrederman's Avatar
I haven't looked at mine... but I will.
Thanks...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 10-22-2013, 07:26 PM   #7
MOD Guy's Avatar
The air return for the heat would not be in the bathroom. You should have a small heat duct behind the grill. Mine was just laying in the space, so a bit of het came out, but not much. I would guess they do it this way to put a bit og het into the closed plumbing area under the tub/shower. A round full sized vent would dump way too much heat into the small space. Had that problem on my Starcraft Hybrid.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 10-23-2013, 11:27 AM   #8
tanddc's Avatar
Robmac,
I just realized what you were talking about. That is not anything to do with heat (or AC). that grill is there to allow air to get in under the tub surround so that it can dry out any water that might get back there (and there are several way this can happen). I had mine off because my shower leaks at times and it goes under the surround.
So, not a heating vent or return. FYI- You should have 1 vent in the bathroom. The return should be in the kitchen across from your furnace. Mine is right under the fridge.
Tim
tanddc is offline   Reply With Quote
Old 10-23-2013, 11:30 AM   #9
DDC
DDC's Avatar
Originally Posted by tanddc View Post
Robmac,
Tim
Well mine has a flexible heating duct in it.
Old 10-23-2013, 11:39 AM   #10
tanddc's Avatar
That is why responded specifically to the OP. We both have sports. I have no idea on the other models.
heating
