Old 06-03-2016, 12:13 PM   #1
BCCamper's Avatar
Hot water tank bypass valve location on 2015 Surveyor 321BHTS
I'm taking my trailer out for the first time since it was winterized but its also only the second year I've had so I've never de-winterized it after the dealer winterized it. The hot water tank won't fill. I can't see a bypass valve does anyone know where one may be? Thanks!
2002 Dodge Ram 2500
2015 Surveyor 321 BHTS
BCCamper is offline   Reply With Quote
Old 06-03-2016, 12:16 PM   #2
wmtire's Avatar
See if this thread with pics can help;
http://www.forestriverforums.com/for...st-103381.html
2011 Flagstaff 831 RLBSS
Old 06-03-2016, 12:17 PM   #3
it should be on the inside "behind" the water heater.
Is your water heater in the kitchen area? Pull out drawers or open cupboards and look inside.
On my old camper I had to remove screws to open an access panel.
Find the interior area that corresponds to the water heater vent on the outside.
mkosu04 is offline   Reply With Quote
Old 06-03-2016, 12:21 PM   #4
MidWest Camper's Avatar
Remove the panel under the pantry door. 4 Philips screws.
MidWest Camper is offline   Reply With Quote
Old 06-03-2016, 12:29 PM   #5
BCCamper's Avatar
Ok thanks I'll try that would have been nice to show me where that was when I bought the unit!
2002 Dodge Ram 2500
Old 06-04-2016, 09:19 AM   #6
BCCamper's Avatar
Thanks a lot Midwest camper I talked the wife through it since I was working and it was right there under the pantry cabinet!
2002 Dodge Ram 2500
Old 06-04-2016, 01:42 PM   #7
Cool. I'm glad I was able to help.
2015 321 BHTS
Old 07-23-2016, 04:34 PM   #8
Buckskin
After removing 4 panel screws, replaced with Velcro for easy access. Keeps panel in place and makes it easier to access bypass for water heater.
2012 Toyota Tundra Double cab 5.7L 2wd towing pkg
24' 2014 Surveyor 201RBS
Buckskin is offline   Reply With Quote
bypass, cat, hot water, location, surveyor, tank, water, water tank
