Old 01-09-2017, 04:10 PM   #11
Suggest you watch the following video.
veraken is offline   Reply With Quote
Old 01-09-2017, 05:01 PM   #12
Hugh R's Avatar
The wifey (OK, maybe it was me) bought non-RV TP once and it clogged something. I have a sewer dump at the house, so I bought a sort of jet, but not high pressure, water wand for the house hose and ran the hose through a window and stuck it in the toilet and ran it around for a while. It cleared all that was clogging it and the black water level sensors started reading properly. I ONLY use that wash wand for that purpose.
2013 Mirada 29SE, I earned it!
Hugh R is offline   Reply With Quote
Old 01-09-2017, 06:03 PM   #13
Originally Posted by Hudgen View Post
Never mind - found what I needed
well Hudgen, I can see you are are getting several folks warning against doing what I described in my post #3, ..... what that is about is, some people clean their tanks by filling the tank FULL or ALMOST FULL then letting that drain out, then doing it again and letting that drain out, and possibly even doing that a third or fourth time, ... I can't imagine wasting 30 to 40 gals. of water on each dump and doing that 3 or 4 times, what a tremendous wast of water, ...... but IF that's how you clean, then sure you have to be very careful because when you are nearing the full level you run the risk of flowing out the vent pipe and making a mess that no one wants to see, ...... I spray my flush unit for about a minute, maybe 1 1/2 mins. at the most, 2-3 gals. each time, total of maybe 10-12gals, max for my whole cleaning process, and will compare my cleaning results with the 100 gal. cleaning process any day, ...... it just isn't necessary, the flush is SPRAYING water all over the tank, washing down everything, .... but anyway, what I described is happening in post #3 is a fact, ..... do what you want to about it, but it ain't necessary to waste 100gals of water to get a clean black tank, ..... happy trailering ..............
fella10 is offline   Reply With Quote
Old 01-09-2017, 06:30 PM   #14
Originally Posted by Teaman View Post
Teaman here.
Any ideas anybody. Is this flush gadget accessible or even repairable???
Will appreciate any tips. Thanks
if your spraying unit has gone bad/stopped working, a simple fix is to install a "quickie flush"(link below), works great, .. and I would install it on the curb side of the tank, you'll get better results over there, see post #3, .....
https://www.amazon.com/Camco-40123-Q...=quickie+flush
Old 01-09-2017, 09:40 PM   #15
fella10 - I agree, I don't need to use 100 gallons of water to clean my tank. Especially if the flush unit works just fine . . .
thanks to everybody for their advise
Hudgen is offline   Reply With Quote
Old 01-09-2017, 11:09 PM   #16
Dump valve open when flushing
Originally Posted by Flybob View Post
I would be very careful running the black tank flush with the dump valve closed. You are introducing water into the tank at a fairly high rate. If you have a clogged or partially clogged or malfunctioning vent, you could get black tank contents where you don't want them or damage the tank.
My camper has a decal near the black tank flush stating it should only be used with the dump valve open. Besides what Flybob has mentioned, I also think the flush does a better job when the black tank is empty.
When I run the flush I can hear the pressurized water spraying against the tank sides - doing its job. If you've got the dump valve closed the spray isn't directly hitting the sides once the water level rises which reduces its effectiveness.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping in 2015, 45 in 2016
CNYCamper is offline   Reply With Quote
Old 01-10-2017, 09:28 AM   #17
Tom48's Avatar
[QUOTE=Teaman;1396328]Teaman here.
Have been meaning to ask sort of similar question. My Black tank may not be flushing properly. I had a strong suspicion something was amiss and recently ordered a clear 45 degree adapter for the drain, to enable observation of the cleaning progress. Sure enough, the Flush sprayer gadget seems to be clogged or not installed correctly. Only a tiny trickle of water is flowing thru the clear adapter while trying to use the flush. The water hose is connected and the faucet turned full on.
I have only owned this 2013 Sunseeker for about six months and am still working the 'bugs' out.
Thanks[/QUOT f
First, if it only a trickle there may be a problem with flow, but we have one on the new TH and it seems slower than my old process and I still use the old process when relying on the dump station hose since the end is usually too messed up to screw on the fitting anyway.
What I do is assume at best the hose running full is at most ten GPM. I have a 40 g tank. I drain it, then pick up the end, a I've tank level and run the hose in it for three minutes.
Lay the hose back in drain. I usually get a large amount of brown and paper. Repeat. Surprisingly, the second time there is usually still a small amount or no paper, but still very brown. Repeat. Usually by third flush I am getting clear water. Done.
Tom48 is offline   Reply With Quote
Old 01-11-2017, 11:46 AM   #18
Boots49's Avatar
Send a message via Skype™ to Boots49
I have a 2010 Wildcat 5th wheel. When we bought it in 2010 the black water tank flush valve was installed backwards. The manual states that the valve only works if the BW valve is open. When we were connected to the black water tank flush & had the BW valve open there would be only a trickle coming out of the tank, which I believe was just more draining water, plus when I disconnected my hose from the black water tank flush I would get a tremendous pressure & water bolt back. My dealer said that I was not the only one that had the black water tank flush valve installed backwards, it has been working great since then. I love the clear 45 degree I installed at the end of the piping because with the cap on it I do not get a surprise when I remove the cap now!
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 01-11-2017, 03:56 PM   #19
Originally Posted by hiinthesky View Post
My black water flush is on the street side. Do I still need to use the knock down pressure gizmo during the flushing of the black tank or do I need to remove the water pressure regulator for higher pressure for flushing the black tank???
The instructions with my flusher are to use full-pressure water. I assume because the flusher is always "on" there's little risk of over-pressure causing a water line rupture.
DrLewie
Flemington, NJ
2007 Cardinal 30W LE
2008 Ford F-250 Long Bed Diesel
Total of 21 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
black, black water, tank, water, water tank
