How to Fix Delamination On 2006 Surveyor
My 2006 SV264 Surveyor has developed some delamination around one of my upper clearance lights on the front of the trailer. I'm assuming the moisture came in around the light and I've purchased some new Bargman lights that I'm going to replace the old ones with and re-caulk but has anyone attempted to glue back down the fiberglass sheeting where it has puckered up. There are a couple of spots just below the light and the largest is approx. 8" to 10" in diameter. Any advice would be greatly appreciated. Also I've seen some posts that say not to use silicone caulking on TT's, could someone explain why not? I had intended on getting some white silicone caulking to place around the new lights upon replacement. The current caulking appears to be a silicone type of caulk but I'm not sure and the original owner is not available to ask.
