Old 05-28-2015, 07:12 AM   #1
How to jack up
I have a Surveyor Sport 240 BR and have a question about jacking up the trailer. My camper has gas lines, wiring and a plastic strip running along the bottom of the frame which is in the way of placing a jack or jack stands on it.
Any suggestions for how to jack it up without using the drive on block easy lift or jacking on the axle ?
frcamp is offline   Reply With Quote
Old 07-04-2015, 08:58 AM   #2
dwm
jacking up camper
I am looking for an answer to the same question. I have a 264 and I wand to jack up one side t o slide additional leveling block under or pull both tires. where do I place the jack
dwm is offline   Reply With Quote
Old 07-04-2015, 09:14 AM   #3
Ford Idaho's Avatar
Why not use the spring U bolt, Use a small piece of wood between the bolt and jack.
It's not like it will be on the jack for hours on end.
Old 07-04-2015, 09:14 AM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
What is the reason for wanting to jack up the trailer? Still best bet to do so is use a floor jack under the axle. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-04-2015, 09:17 AM   #5
Unless it is a torsion axle and YOU CANNOT JACK ON A TORSION AXLE!
Old 07-04-2015, 09:22 AM   #6
dwm
leveling
Just suppose I am at the campsite and I want to level it up a little better and I am disconnected from the truck.
Old 07-04-2015, 09:40 AM   #7
fast murray's Avatar
Put the correct height of blocks under the tires.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 07-04-2015, 09:49 AM   #8
Ford Idaho's Avatar
I once parked to close to a power pedestal for the slide to go out all the way.
Tight site required me to make all water and power connections with the slide in.
I just unhooked everything after putting the slide back in, hooked the lite up and moved over, yes it was a pain but I will not make the same mistake again.
Old 07-11-2015, 02:02 PM   #9
schrederman's Avatar
Mine has torsion axles. I use a piece of 2X4 and floor jack at the point where the suspension and frame are connected. I use 2 1.5 ton aluminum, racing floor jacks and jack both axle attach points. Takes a bit of effort, but works great.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
