Old 05-11-2010, 09:34 PM   #1
How to mount lcd tv in the 293???
I just purchased this model and was hoping someone could help me out. Any information will be a great help. Thanks.
hooperjp is offline   Reply With Quote
Old 05-12-2010, 03:40 PM   #2
What size of LCD.?
Flagstaff 29BHSS
One wife
Two girls
two dogs
hdavinc is offline   Reply With Quote
Old 05-12-2010, 04:03 PM   #3
It is actually a LED. 26" and only 11.8 lbs.
Old 05-12-2010, 04:10 PM   #4
If you pick u a flat panel wall mount form the source, vantage point makes one its about $30 - $40 they a easy to install and should screw right into the ent center wall.
Flagstaff 29BHSS
One wife
Two girls
two dogs
Old 05-12-2010, 05:41 PM   #5
What type of studs are in the entertainment center? Wood or Metal?
Old 05-12-2010, 06:38 PM   #6
I found wood in mine.
Old 05-13-2010, 12:21 AM   #7
Hey, I have the same model. Just picked it up last month and going to mount a TV next month. Let me know how it goes.
Haligan is offline   Reply With Quote
Old 05-13-2010, 05:41 AM   #8
milzat's Avatar
Studs in the sidewall are Aluminum. Studs in the partition walls are wood.
If you're wanting to mount the tv on a partition wall, is should be easy to find, just push on the wall. The walls will flex a bit where there are no studs. When you get to an area that doesn't flex, you've found a stud.
milzat is offline   Reply With Quote
Old 05-13-2010, 05:45 AM   #9
milzat's Avatar
Check out this thread .
Old 05-15-2010, 08:47 AM   #10
STATIC's Avatar
Here's the LED TV I put in my trailer, bought a piece of oak, drilled some holes and stained it. I used liquid nail to glue it to the wall, the screws are 3 quarter inch. Been on a couple of trips with it on the wall. Pretty sturdy..
ID:	2488   Click image for larger version
ID:	2489   Click image for larger version
2008 Tundra Crewmax
2006 21ss Rockwood Roo
2008 Hardknock
STATIC is offline   Reply With Quote
surveyor
