Old 03-26-2019, 08:12 AM   #1
Smile Just got a 2017 Surveyor LE 243RBS
Hello-
I just bought a new to me 2017 Forest River Surveyor LE 243RBS and I would like to know if anybody here has a schematics of the layout. I would like to add a TV in the master bedroom and I would like to add some shelves/racks in other areas and would like to know where the electrical/water lines are in the unit.
Thanks,
Name:	243RBS floor plan.jpg
Looking for some fine wine!
PRRUM007 is offline   Reply With Quote
Old 03-26-2019, 11:08 AM   #2
clarkbre's Avatar
I'm not sure exactly where all the wiring is in the trailer. Chances are good it's going to be low along the wall or near the corners to get up to the ceiling lights. For shelves you will likely be ok.
As far as mounting a TV in the bedroom, it's actually a very easy install to secure the mount to the wall. I added a 24" and drilled a 1" hole for the HDMI and cable to pass through. Using a HDMI splitter off of a blue ray player, we are able to watch movies in the main room or the bedroom.
Here's a link to the install and finding the backer board to attach the TV mount.
TV Mounting 101
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 03-26-2019, 02:00 PM   #3
bikendan's Avatar
Wiring diagram doesnt exist.
Equalizer WDH
Old 03-26-2019, 04:26 PM   #4
I added a TV in the bedroom on our 2018 243RBS. Thread is here: TV mount point in 243 RBS.
If the 2016 is like my 2018, there are power and antenna/cable connectors located on the pocket door wall. The key thing for me was finding a 1x4running across the width of the wall at about 5' above the floor. I attached the KeBloc to that board and used some self stick channel to dress the cable and cord.
Alternatively, you could carefully drill through from the hole behind the main room TV. There only a few wires on that wall that you can't find near that hole. Also, you can look into the wall next to the pocket doors.
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2019 F-250 XLT 6.2L 4x4 Crew Cab
mawilson is offline   Reply With Quote
surveyor
