Old 04-05-2019, 10:59 AM   #1
Leveling -
Surveyor 20MBLE
When leveling side to side with my dual axel, I only place a leveling ramp under one wheel on the side that needs to lift. on the other tire on that side,.... nothing. Of course I then put a chock under all other tires for safety.
This is norm right.... that side to side leveling is done by one tire or wheel only?
gbaldwin is offline   Reply With Quote
Old 04-05-2019, 11:09 AM   #2
SPRING IS COMING!!!
BriaBeck's Avatar
Typically, you would put a block/leveler/ramp etc. under both wheels on one side.
If you only put a block under 1 wheel, you'll only get about half of the height of the block you use... ie-- if you put a 2" block under 1 tire, it will only raise that side up about 1 inch.
Brian & Becky
__________________________________
2018 Avenger ATI 27RBS, pushing a 2002 Chevy Silverado 2500HD Duramax w/ Allison 1000
BriaBeck is offline   Reply With Quote
Old 04-05-2019, 11:15 AM   #3
Fulltime family RVer
Always both.
Old 04-05-2019, 11:51 AM   #4
bikendan's Avatar
Always both.
x2
Equalizer WDH
Old 04-05-2019, 12:09 PM   #5
Thanks for comments... raises another issue ... with the leveling blocks or ramps supplied with my TT from dealer, there is not enough space between the two tires to put one of the ramps between them. So if I am pulling forward onto the leveling ramps/blocks or backing onto them, I would need to put a ramp between the two axel/tires. Not room for it? Am I explaining this clearly?
Old 04-05-2019, 12:29 PM   #6
Not knowing what the dealer gave you as levelers we are guessing.
Maybe you have the Andersen Levelers?
If so you may have to cut part of one of them off if the wheels are too close together. Common issue and discussed many times.
Here is a link to a search... Anderson Leveler
Oh... and it is axle, not axel. Sorry... pet peeve.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 04-05-2019, 12:48 PM   #7
Thats it.
Old 04-05-2019, 12:50 PM   #8
Excuse me... That's it! Thanks
Old 04-05-2019, 12:52 PM   #9
_______________
Old 04-05-2019, 09:08 PM   #10
I use 2*6"s and if I want about a quarter bubble lift I only put under 1 tire, half bubble, 2 tires and so forth till level. I use a 4' level on the floor of my 5th wheel just inside the door.
corocky1998 is offline   Reply With Quote
leveling
