Old 07-25-2016, 12:51 PM   #11
Originally Posted by DonMar View Post
I upgraded the tires on my forest river surveyor today went to e load but could not find max rim pressure on rim. Went on line and it's 60 psi and the maxxis are good for 65 psi so I guess I will have too run them at 60 max. any thoughts on this ,I know that tires get a lot time here.
We ran 80 psi lr Es with lr C 60 psi rims when we upgraded the tires on the old trailer from C to E and went years with no issues. We didn't ever have another flat or even a pressure leaking issue for years after the change. I sure would not worry about 65 lbs on a 60 psi rated rim.
Tom48 is offline   Reply With Quote
Old 07-25-2016, 05:52 PM   #12
Question for Tireman9
On cars and trucks, there is a specified tire pressure based on (I assume) the weight and handling of the vehicle. Why is it different for a trailer tire? It seems if you upgrade the load rating on your trailer and up the pressure, it would ride rough and be hard on the trailer.
mnoland30 is offline   Reply With Quote
Old 07-25-2016, 09:08 PM   #13
Airdale's Avatar
Tire inflation pressures are not arbitrary, they are set by vehicle manufacturers as described - in part - in this reference and others referenced within this one.
https://www.gpo.gov/fdsys/pkg/CFR-20...sec571-110.xml
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is offline   Reply With Quote
Old 07-25-2016, 09:50 PM   #14
Big Brother has nothing to do
All that information must mean something to the fed. O'Reily asks simple questions and never gets an answer. Same with that.
FR sent our trailer with spare rim rated for 2150 lbs. with D range tires rated for 2450 lbs. I believe and I'm looking at E range Maxxis.
"At this point in time, what difference does it make?"
Charles & Martha Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2016 Flagstaff V-Lite 30WFKSS
Almost South of the Border
whatsupchuck is offline   Reply With Quote
Old 07-26-2016, 11:11 AM   #15
Airdale's Avatar
What it boils down to is your perception of safety. I'm surprised your would contemplate using tires with a maximum 80 PSI rating on rims with 65 psi rating.
Why did you not return the spare tire/rim assembly to FR?
Tire manufacturers must provide a list of acceptable rims to be used on every tire they make. They must provide access of such lists to the public. All tire retailers have such listings for the tires they carry/sell.
Vehicle manufacturers are required to make tire/rim fitments that are appropriate, meaning the OE fitments meet minimum standards for the vehicle they are fitted to.
When making selections for replacement tires other than those the size of the OE tires, an owner really needs to consult with tire retailers that are fully trained in the procedures that follow tire industry standards for such fitments.
If you are so dissatisfied with the OE tires that came on your unit why would you use your replacements on rims that are not earmarked for the tires you want to use?
USN - RET - PDRL
SSA - RET
Old 07-26-2016, 11:37 AM   #16
SeaDog's Avatar
I honestly believe there is some confusion here. I think folks are mixing max tire pressure with max rim pressure. I have never heard of a trailer rim limited to 65 psi, with that said I may be wrong as often happens. I promise not to get offended if someone tells me I'm full of well you know.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-26-2016, 12:02 PM   #17
Airdale's Avatar
Reference from a popular rim OEM provider.
T02 | Sendel Wheels
USN - RET - PDRL
SSA - RET
Old 07-26-2016, 12:13 PM   #18
SeaDog's Avatar
holly molly batman enough said
Retired Navy
2006 F350 6.0
AF&AM of Idaho
Old 07-27-2016, 11:58 AM   #19
Commercial Member
Trailers are run at or above the tire max load capacity almost all the rime while cars almost never are.
The Interply Shear comes from the fact that trailer tires are dragged around all corners while cars and TV are not. This increases the force trying to tear the tire apart by about 24%
I write a blog on RV tire application and safety. RVTireSafety.com
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
Old 07-27-2016, 12:03 PM   #20
Commercial Member
Rim should be returned to FR for replacement. Also a complaint filed with NHTSA for FR providing potentially unsafe wheel for the application.
Good for you for making the effort to learn what the ratings are on the parts FR gave you.
pressure, tire
