My list is lengthy, and I hope that I recall everything....
Bath:
Added wire shelf under sink
Added wire shelves in wardrobe style cabinet
Added hand-held sprayer for toilet
added net shoe-rack for 8+ pairs of shoes
Hinges and latch on "dummy" panel for new-found storage space.
"Designer" towel racks (hold more and bigger towels than factory racks)
Oxygenics shower head
Kitchen/Dining/Living Area:
Wine bottle rack on wall
Wine glass rack under overhead counter
Replaced plastic sink and faucets with stainless steel
Added splashguard at end of sink to keep water from splashing on sofa
Replaced tin stove cover with wood cutting board cover.
Modified bench seat covers and dividers to maximize available storage.
Key rack next to door.
Replaced factory XM mount (never used - I sold it on-line!) with a Sirius mount
Installed black, wet erase marker board (to cover big hole from XM mount)
Added oak rails to shelf openings under television to hold things in place while in transit.
Installed Red Devil built-in vacuum system under bench seat (hose can reach throughout unit, plus into front storage compartment)
Bedroom:
Installed 19" LCD and DVD player on wall.
Installed 30" 12v Casablanca-style fan on ceiling, over bed
Installed clothes hooks on each side of bed.
Added wire shelves to one wardrobe cabinet
Modified under bed storage, by hinging top, installing prop rod, and removing small drawers to maximize storage area. Drawer faces were reinstalled with hinges and latches.
Installed NOAA weather alert radio. (hard wired to 12v system)
Outside Storage Compartment:
Added thumb latches to supplement locks (so that I don't always have to use key to keep latched)
Installed peg-board storage rack on "front wall". Multiple tools, awning hook, saw, hatchet, axe, etc now hang on pegboard.
Installed rack to hold flagpole, and other "stuff" off of floor.
Covered entire storage area floor with "Turtle-Tiles". Resilient, rubber, easy to clean, etc.
Added Outside Storage:
Added rear bumper storage box for macerator pump, 50' "black" hose for macerator pump, black tank/system fittings, extra hose, etc.
Installed two 6"x 6" tubes under frame. One holds stinky slinky's, the other holds awning bows and an outside entry carpet.
added shelves in outside storage compartment on slide.
Replaced factory battery-box with diamond plate tool-box. Now holds four (4) full-size batteries, plus additional storage.
General Plumbing:
Added accumulator (pressure) tank to fresh water system
Added Tornado wash to black tank
Added solar-power fan to roof vent stack
Installed 1/2" pipe insulation on all hot water plumbing.
Upgraded plastic water supply fitting (leaked from first use) with brass fitting.
General electric:
Replaced single 12v battery with four (4) 6v golf cart batteries.
Installed 300w of solar panels on home-made 4-way tilt mounts on roof.
Installed MPPT controller to charge 12v system from solar, and to regulate panel outputs.
Installed 2000w Xantrex Inverter to produce 110v AC from battery bank.
Installed necessary wiring to provide 120v throughout TT when Xantrex is on.
Installed five(5) 12v cigarette lighter style plugs throughout unit.
Replaced all 12v incandescent interior bulbs (including bulb in refrigerator and bulb in range hood) with LED lighting.
HVAC:
Installed delay timer on A/C compressor, providing "soft start".
Replaced mercury thermostat with Hunter digital t-stat.
Other:
Replaced factory "Chinese Bombs" with Kuhmo 857's
Installed TMS monitoring all five TT tires and all five TV tires.
Installed four (removable) awning bows.
Added Extend-a-tank propane system.
That's all that I can think of off the top of my head...... for now!
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
