Old 03-15-2016, 07:38 PM   #1
New 295qble
This is my first travel trailer and we are having some issues with our trailer. It seems the batteries are draining in about a week when stored. The lights and water pump might work but the slide does not. Do you install a battery disconnect or just pull the batteries.
I am thinking of making a bike rack to go in between the bunks. Anyone tried that?
Thanks Jason
Oliphanj is offline   Reply With Quote
Old 03-15-2016, 10:26 PM   #2
Carbon Monoxide sensor uses juice and can slowly kill it. You can disconnect the battery. We keep ours hooked up to shore power when it's in the driveway.
Humteddy2
2014 Silverado LTZ 1500
2016 Surveyor 285IKDS
Humteddy
2017 Surveyor 285 IKDS
2016 GMC Sierra Denali HD 2500 Duramax
Humteddy2 is offline   Reply With Quote
Old 04-10-2016, 11:28 AM   #3
talmadge's Avatar
I put in a battery disconnect. My battery would drain in about two month when stored in the back 40. would here a beeping noise meaning low battery so that is why I did that.
talmadge is offline   Reply With Quote
Old 04-11-2016, 10:24 AM   #4
Coolharts's Avatar
If you can get the adaptors for your shore power cord so you can plug it into an extension and wall outlet, the battery will stay charged.
I installed an RV 30 AMP circuit and plug my unit in, it is so nice to be in it in the summer and run the A/C.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
Nights Camped 2018 4 Scheduled 25 (so Far)
Coolharts is offline   Reply With Quote
