Old 07-15-2014, 02:18 PM   #1
MOD Guy's Avatar
New Faucet
Well, the factory faucet that I have never cared for got replaced while we were on vacation. A few years ago a valve in the faucet failed (Could not turn off fully), so I just replaced the valve. The cabinet under the sink makes it a PITA to access the connections, so I did the valve thing.
At the start of our vacation, at out overnight stop, I noticed water on the counter. I had a slow leak at the base of a valve.
We made a stop at Lowe's and when we got checked in and setup at our vacation destination, I changed the faucet. It was a pain to get to the connections. The removal took a while, but the new install went fairly smooth. Leak free on the first try
This one is metal, the orig. was plastic.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 07-15-2014, 05:30 PM   #2
We did the same, but replaced with one that had a sprayer nozzle - it is the DW's favorite mod
2013 Forest River Surveyor SV305
2011 Ford F350 King Ranch (Diesel)
1 Wife, 2 Dogs, 3 Kids
LOTS of grey hair!
orcusomega is offline   Reply With Quote
Old 07-28-2014, 12:32 AM   #3
what did you guys do to adapt the factory water supply fittings to the new faucet fittings?
700hauler is offline   Reply With Quote
Old 07-28-2014, 01:25 AM   #4
2007 WildCat 32QBBS
05CrewDually's Avatar
I used standard flex lines (braided stainless) available at any plumbing supply.
Sent from my KFJWI using Tapatalk
05CrewDually is offline   Reply With Quote
Old 07-28-2014, 02:31 AM   #5
Cornelius's Avatar
I used Watts compression fitting adapters part # LFA-124 ($6.49 each at Lowes) to connect the existing plumbing fittings to my new kitchen faucet.
Orcusomega, you and I have the same good taste in faucets. I just installed the same model a few days ago. It was a PITA accessing the plumbing lines behind the sink...
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 07-30-2014, 07:53 PM   #6
MOD Guy's Avatar
Since I was on the road with limited tools, I elected to go with a faucet that was a direct swap for the existing one. Same hole location and fittings matched old to new. Had I been at home with my tools, I may have went with a center pullout, which would require a new hole to be drilled in the countertop, along with changes to the fittings.
High Springs, FL.
Old 07-31-2014, 04:01 AM   #7
cpaulsen's Avatar
Did ours a couple of years ago with some from HD. Used a pullout spray faucet in the kitchen and swivel arm in the bathroom. They both fit the existing holes perfectly.
cpaulsen is offline   Reply With Quote
Old 08-03-2014, 04:25 PM   #8
I was going to upgrade and use another pull out spray faucet (similar to the factory one that developed a leak) but upon further thought I decided that the pullout was not needed for our typical use so I went with a simple tall neck faucet like MOD Guy did. I figure the simpler the better in our trailer that sees temperature extremes from sub zero to 100+ Fahrenheit.
faucet
