Old 06-27-2018, 10:19 AM   #1
New MORryde sliding tray
Just wrapped up installing a 26"x90" two-way sliding tray by MORryde in the front pass through. It slides out about 3' to either side making the stuff in the middle easy to get to. Available height is reduced to 12" clearance but, that limit is overcome by accessibility. I mounted it aft to leave room for broom clips and not crowd the light and switch mounted forward.
Mounting details:
- The thing is heavy but, I was able to get it in by myself.
- I needed to add a spacer so the pop rivets would clear the door frame. I used 5/32 x 1 1/8 x 8' PVC lattice running the length of each side rail. That gave ~1/16 clearance.
- I drilled 5/16" through holes and installed 5/16 x 3" stainless steel carriage bolts with stainless fender washers and stainless nylon lock nuts. I applied butyl tape to one side of the fender washers to seal it up.
Pics attached. As you can see, I'm still working out stowing details.
ID:	177427   Click image for larger version
ID:	177428   Click image for larger version
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2019 F-250 XLT 6.2L 4x4 Crew Cab
mawilson is offline   Reply With Quote
Old 06-27-2018, 10:57 AM   #2
I made my own out of angle iron, plywood and garage door track that does the same thing.
Name:	Basement drawer out as far as it will go curb side.JPG
ID:	177437   Click image for larger version
Name:	Basement drawer tethered out the driver side 1.JPG
ID:	177438   Click image for larger version
ID:	177439   Click image for larger version
ID:	177440   Click image for larger version
Old 06-27-2018, 11:03 AM   #3
BandJCarm's Avatar
Have the 36 X 90 MorRyde tray installed in basement of 5th wheel. Wonderful product and very functional
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 06-27-2018, 11:29 AM   #4
Looks good. I thought about those too, just not sure I could store as much stuff as without the tray.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 06-27-2018, 12:24 PM   #5
MorRyde tray
Nice install. I had one put in by my dealer prior to taking delivery & love it. No more banging my head reaching for things. I found that when I loaded it, I didn’t need as much “stuff” as I had in my previous trailer...
RRGuy55 is offline   Reply With Quote
pass through, slide, surveyor, tray
