Old 05-02-2016, 08:16 AM   #1
209surveyor's Avatar
New Surveyor Antenna Wobble / Info ?
On my new 243RBS, the tv antenna wobbles. Dealer tech thinks it's normal, but I'm not sure. The horizontal part of the antenna is what wobbles, the vertical piece mounted to the roof is fine. Haven't found any info on this, or even a brand name in my paperwork. Is anyone else's antenna wobble? Any info is appreciated.
2016 Surveyor 243RBS
2015 Titan: K&N, Leveled by Bilstein
U.S. Army Vet "This We'll Defend"
209surveyor is offline   Reply With Quote
Old 05-02-2016, 08:36 AM   #2
Mine does the same. Slight wobble, no means to tighten it, nor to tune / rotate it. I guess, this is the new normal with these.
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
2016251RKS is offline   Reply With Quote
Old 05-02-2016, 04:11 PM   #3
Thanks for letting me know. Going to have dealer look at it again while they have it for a few other issues. It's kind of annoying when you're sitting inside and its taping away in the wind.
Old 05-02-2016, 04:21 PM   #4
Antenna wobble
I have the same problem on mine, 2016 251RKS. I just plan on replacing it with one of the King units.
Rick
Sounnder is offline   Reply With Quote
Old 05-02-2016, 04:24 PM   #5
What's a king unit Years ago my 34'winny had a winegard that was cranked up and rotated . . how time changes
Old 05-03-2016, 10:53 AM   #6
Traveling Two
jerryliving's Avatar
Ours also vibrated in the wind so i removed the antenna, wrapped black tape around top of post. Fixed.
jerryliving is offline   Reply With Quote
Old 05-04-2016, 07:45 AM   #7
Thanks for the info everyone. Sounds like replacement / removal are the options, vs. fixing.
Old 05-04-2016, 07:55 AM   #8
Traveling Two
I forgot to add that after I removed the antenna and wrapped electrical tape around the top of the post I put the antenna back on and the rattling was stopped.
Old 05-04-2016, 10:31 AM   #9
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
You have the same antenna as I "had" on my Surveyor Fifth Wheel. Reception was crappy, so replaced it with a King Jack and haven't looked back. Suggest you look into doing it too. Happy Camping.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 05-04-2016, 11:34 AM   #10
jerryliving, until you said something I didn't really think much about it except that you removed it. Makes more sense now, and gets rid of the rattle. Will have to look into it. Thanks.
antenna, surveyor
