Old 06-21-2010, 07:58 PM   #1
Noisy Radio
Hi all,
I've heard that the radios in the Surveyors were troublesome prior to the 2010 year. Well, the radio in my new 2010 trailer emits a fairly loud constant buzz when its on. I'm planning to have my dealer look at it, but considering the history of the poor radios, is this as good as it gets, or should I expect to have better quality? Are there aftermarket options out there?
Thanks,
Cory
2011 GMC Sierra 2500 Diesel Extended Cab
2013 Columbus 340RK
hanther is offline   Reply With Quote
Old 06-21-2010, 08:12 PM   #2
milzat's Avatar
Hi Cory,
Welcome to FRF.
There has been a couple post about this. Try doing a SEARCH for Radio Noise.
Also, click here .
milzat is offline   Reply With Quote
Old 06-21-2010, 09:00 PM   #3
Hi Cory, we had the same problem with noise in our Concertone radio in our new Rockwood anytime it was hooked to shore power. However the noise wouldn't be there if just running off of the batteries. As suggested by others I installed chokes or as some call them noise suppressor's. Check my previous posts where I listed the parts #'s that I bought from Radio Shack.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 06-21-2010, 09:17 PM   #4
Thanks to you both for the quick response! I just want to clarify that the noise was coming from the actual stereo itself and not through the speakers, was that your situation as well emptypockets?
If so, I'll definitely have a look at the noise suppressors
Thanks again...
2013 Columbus 340RK
Old 06-21-2010, 10:39 PM   #5
radio noise
Originally Posted by milzat View Post
Hi Cory,
Welcome to FRF.
Also, click here .
Cory, click on the red & it will describe what I did.
Old 06-21-2010, 11:40 PM   #6
Try grounding the radio's metal cabinet to a good ground in the trailer. If an electrical junction box is not plastic, try that. Other than that, buy a filter from Radio Shack.
Big Bird
Big bird is offline   Reply With Quote
Old 06-22-2010, 11:19 AM   #7
Just a hint as to the trouble, mine was buzzing loudly as well and then went away. So i forgot about it, recently i looked at attaching an ipod to the stereo and i had to remove it from the wall. Anyway when i replaced the unit back in it's housing again the buzzing was back. hmmm? i losened one screw on the housing and the buzz went away. I'm happy again! Give it a try guys it may be as simple as that. Also to access the stereo remove two black strips on either side of the radio. you'll need a flat top screw driver to depress the two tabs along the side and they pop right off. The screw on the bottom right corner was the problem, as to why it does this i don't know.
Logan's Run is offline   Reply With Quote
Old 06-22-2010, 05:31 PM   #8
mjones12's Avatar
I had the one in my 2010 replaced under warranty because it only worked sporadically. The guys who replaced it said the hissing noise I was hearing in both the old one (when it worked) and the new one was the fan inside the unit. At least in my case, the noise was not coming through the speakers. They said Forest River does not consider a loud fan to be a warranty issue. But it's still a piece of junk, in my opinion, and does not have a good sound. I will probably end up replacing it with a Jensen unit that I saw at Camping World.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 10-23-2010, 09:06 PM   #9
Walke's Avatar
Noisy Radio in Surveyor
Yes, the radio is a "pirce of junk". Mine was the same as MJones12, the small cooling fan was causing the noise. I cut a wire and stopped the fan. I have run the radio for hours in the Florida heat as well, no problem. The fan was not very efficent and the electronic components can take the heat, when it cooks, no real loss, I will deal with it if and when it happens. In the mean time, the radio is clear.
Ken & Judy
2012 Prime Time Lacrosse 301RLS
2014 Ford F-150 Lariat - Max. Tow - Ecoboost
Hensley Arrow Hitch
Average 50-60 nights/yr
Walke is offline   Reply With Quote
Old 10-24-2010, 09:00 AM   #10
acadianbob's Avatar
Our Concertone had a constant hiss. We replaced it with a Jensen AWM970. Well worth the change. I have a post on this board somewhere with pictures if you do a search.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
surveyor
