Old 09-27-2014, 04:26 PM   #1
Outside BBQ Connection problem
We have a 2015 SP240RBS that we got to use for the first time this week. There is a connection for an outside BBQ under the outdoor kitchen with a quick coupler and shut off valve. I purchased a hose at Camping World to connect from the connecter to my Coleman BBQ, but I cannot get any gas to flow. There is a 90 degree shut off valve right behind the coupler, and I have tried it in both positions. Has anyone else ran into anything similar? Thanks!!!
Mad Dog 7.62 is offline   Reply With Quote
Old 09-27-2014, 04:33 PM   #2
wmtire's Avatar
What kind of hose did you get to connect to your Coleman? It may not be coupling correct, thus not opening the internals for propane to flow. Also what Coleman grill do you have?
The reason I ask, if you have a Coleman with it's own built-in regulator...then connecting to the Low pressure propane line on the RV isn't going to work correctly.
We just discussed this yesterday here:
grill conversion
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 09-27-2014, 08:02 PM   #3
Oh. That makes sense. Yes, the line connects into the main propane line after the regulator then connects to the regulator on the grill, so its being "regulated" twice. Time for plan B.
bbq
