Old 08-30-2016, 06:06 AM   #1
Cmmjmoore's Avatar
Outside Kitchen
We have always stored our unit on the side of our houses with it tied to power, looks like we will have to store it off site for a couple of months and I am concerned about the outside refrigerator and mold. What suggestions do you have with this issue. There isn't enough room to leave the door opens when the cover is down. I though about removing the doors but that seems extreme. Any ideas would help-thanks
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
Cmmjmoore is offline   Reply With Quote
Old 08-30-2016, 06:09 AM   #2
Life is great's Avatar
Did you take a look to see how easy it is just to take it out? Mine is held by 2 screws from below. To take the door off you'd have to remove it anyway.
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - ??
Life is great is offline   Reply With Quote
Old 08-30-2016, 06:10 AM   #3
Can you just prop the door open somewhat?
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 08-30-2016, 06:24 AM   #4
We just prop the door open. Never had any mold at all in two years of winter storage. Just make sure the inside is dry and clean when you put it away.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
Old 08-30-2016, 06:41 AM   #5
Iwannacamp's Avatar
I used to unplug the fridge and stick the cord inside...this kept it open just a bit. Never had any trouble.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Iwannacamp is online now   Reply With Quote
Old 08-30-2016, 07:08 AM   #6
Flybob's Avatar
We use a 6" piece of pool noodle slit down the side on the door frame. Keeps it open about 1". Never had any issues. Also have a strap around entire fridge while traveling to make sure door stays closed in case things shift and hit the door. Use the same strap to keep door from swinging all the way open when storing.
PS: Pool noodles are RVers duct tape.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-30-2016, 07:35 AM   #7
Cmmjmoore's Avatar
I guess my frig and kitchen door have less clearance no way will the door stay open more than 1/2" when the outside door is closed. . If it ever stops raining here in Texas I will turn it off and leave it open all day. Good idea about removing it but sounds like a lot of trouble. Thanks for the suggestions.
(2011-42)
outdoor kitchen
