Old 09-05-2015, 10:35 AM   #1
armyfa78's Avatar
Outside TV mount 321bhts
Anyone have any insight on what it takes to detach interior TV and move outside to use for exterior mounting ?
armyfa78 is offline   Reply With Quote
Old 09-05-2015, 10:37 AM   #2
nomad297's Avatar
Try lifting the TV straight up and out.
Bruce
nomad297 is online now   Reply With Quote
Old 09-05-2015, 11:30 AM   #3
Left Coast
Do you already have an outside mount? Is it a V shape?
Old 09-05-2015, 03:10 PM   #4
armyfa78's Avatar
I believe it's more oval shaped with a slit in the top
Old 09-05-2015, 03:24 PM   #5
Left Coast
Use that as a guide as to how to remove inside one.....some tv's have a small cable attached to bracket and wall. the wall end is attached with a screw to keep tv on the wall while traveling...
Old 09-06-2015, 07:05 PM   #6
Mine has a nylon strap that hangs behind TV and you have to pull strap down as you pull bottom of TV outward (towards you).
Gmar60 is offline   Reply With Quote
Old 09-06-2015, 07:24 PM   #7
AdamC's Avatar
Pictures of it in this thread:
2016 Surveyor 32RKDS
AdamC is offline   Reply With Quote
Old 09-18-2015, 05:07 PM   #8
armyfa78's Avatar
Thanks Gmar. It's exactly the way you described it ..
Old 09-18-2015, 06:00 PM   #9
The worst day camping is far better than the best day working.
mount, tv mount
