Old 11-17-2018, 05:33 PM   #1
Power for Outside Fridge
The fridge in the outdoor kitchen of my 243RBS runs off shore power with no propane option like the indoor fridge. That means no power while we're under way. It would be awesome to put lunch in the outdoor fridge for a rest area/wayside park picnic. So, the question is: how to power the outdoor fridge while underway? A secondary inverter?
Mark Wilson
No trees were harmed while sending this message;
however, a rather large number of electrons were terribly inconvenienced.
TT: 2018 Surveyor 243RBS TV:2012 F150 5.0L Scab
mawilson is offline   Reply With Quote
Old 11-18-2018, 11:41 AM   #2
clarkbre's Avatar
We use frozen water bottles to maintain the temperature after chilling it on shore power prior to leaving. With 4 or 6 frozen 16oz bottles, you'll get through a travel day easily without thawing out. Then, repeat when on shore power.
A separate inverter would work for the fridge; however, it would likely put a large drain on the battery(ies) with little gain.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 11-18-2018, 12:09 PM   #3
I turn mine down as low as it will go. After a days travel it is around 50 in there which is about the same as if the things were in an ice chest.
Hank, Dianna and two fur babies Cody and Bella
2016 F250 PSD CC/SB
2018 Crusader 338RSK
Windjammin is offline   Reply With Quote
fridge, power
