Old 06-26-2017, 08:25 PM   #1
Unhappy Problem with the Water System
Hi All,
Today I put on a new Camco Blue Filter, so I ran the water for awhile to clean out the Carbon and then I hooked it up to the Trailer to check for water leaks, I found that there was no Water coming out of any of the Faucets, the line that come from the Water Hook Up, goes to a Valve under the Sink and that Valve is making noise, is that Valve stuck?
Then I noticed there was Water coming off the Roof from the Bathroom vent pipe and there was water on the bathroom floor. so is the problem in the Valve or somewhere else?
TT is a 2012 Surveyor SV264
1st Time Rv'er
2012 Forest River Surveyor Select SV264
2013 Chevrolet Silverado HD2500 Duramax 6.6 HD
timcbs is offline   Reply With Quote
Old 06-26-2017, 08:36 PM   #2
fonzie's Avatar
From your description I think you hook to the black tank flush and not to the city inlet.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-26-2017, 08:40 PM   #3
Flybob's Avatar
X2 Think you connected to the black tank flush. Black tank full. You are not the first to do this, Check the black tank to insure it was not damaged by the pressure.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-26-2017, 09:12 PM   #4
bikendan's Avatar
x3!
Equalizer WDH
Old 06-26-2017, 09:23 PM   #5
Ya, what an idiot I am, have only hooked it 100 times.... HA HA HA
Thanks All
1st Time Rv'er
Old 06-26-2017, 09:24 PM   #6
Oakman's Avatar
I agree with the others, you have hooked up to the black tank flush.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-28-2017, 07:28 AM   #7
If the water is all the way up to the roof in the vent, do not try to flush the toilet.
markb422 is offline   Reply With Quote
Old 06-28-2017, 08:04 AM   #8
Thanks markb422, I did not flush, I Black Water Tank is full.
1st Time Rv'er
Old 06-28-2017, 08:08 AM   #9
You really should try to empty that as quickly as possible.
Days Camped: '16=46 '17=30 '18=51 '19=42
water
