Old 04-23-2014, 06:19 AM   #11
lswartz's Avatar
I just disconnect the positive cable at the battery. I have easy access the batteries on my TT, some do not & a switch would be much simpler once it is installed.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 04-23-2014, 06:27 AM   #12
Herk7769's Avatar
I have found it easier (and safer) to disconnect the negative. That way you only have to worry about your tools touching the positive terminal when working on the battery. If you are working on the positive terminal every bit of metal is the enemy if the ground is hooked up.
When removing the battery (for service or replacement) I always go negative first to remove and last to install for that reason.
HAM CALLSIGN - KC3FFW
Old 04-23-2014, 06:41 AM   #13
PSUFan1's Avatar
Battery disconnect switch is on my to do list this year. Some good threads on here talking about it.
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 05-10-2014, 11:46 AM   #14
Propane alarm goes on
Originally Posted by markb5900 View Post
Is your battery low? that will cause it to go off.
How low is low? Is the alarm connected to the coach batteries (I have 2 on my Sunseeker 2300) or the main battery?
davegood is offline   Reply With Quote
Old 05-10-2014, 12:17 PM   #15
Professional Texan
TexasBob's Avatar
I bought this simple battery disconnect switch at Wal-Mart and a larger battery box. I put the switch on the negative side of the battery.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 05-11-2014, 07:52 PM   #16
lswartz's Avatar
You are so right! I can't believe I said positive terminal. Sparks will fly.
propane
