06-11-2017, 09:44 PM
Propane Stove Recommendation
Our 2016 251RKS has the propane stove prep. Can anyone suggest a stove that has a connector that will plug directly into the prep on the side of the trailer?
2016 FR Surveyor 251RKS. Mods (so far): 2nd battery with solar battery tender, cover, Air Maxx vent covers
06-11-2017, 11:29 PM
It's a propane pre-connect for a bbq grill.
It's low pressure so the only stoves I know that will work, are popup stoves.
06-12-2017, 12:21 AM
I removed the pressure regulator from my grill and added a hose with a quick connect connection. Larry G.
2021 Silverado RST Z71 4x4 6.2L
2021 Flagstaff Micro Lite 25FKS
USMC (Retired) '70-91
06-12-2017, 01:11 AM
Depends on what stove he has.
06-12-2017, 05:49 AM
I ordered a Flame King 2burner interior stove and lid off of Amazon. Built a box for it. Purchased a hose quick connect from Propane Gear. Put it all together. If interested, I can get you a parts list.
06-17-2017, 09:34 PM
Thanks for the input everyone. Wish there was something all plug & play instead of having to make all these modifications to a stove to be able to work in the factory propane supply.
06-17-2017, 10:32 PM
Problem is that most propane stoves are high pressure and all RV propane supply is low pressure.
That's why I bought a Camp Chef stove with a BBQ grill box.
Plugs right into the quick connect.
06-17-2017, 11:43 PM
I don't think our 2017 has a connection on the outside. Where on the trailer is yours?
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
07-04-2017, 08:53 PM
It's on the side with the awning, between the wheels and the pas thru storage.
You have to bend down & look under the side skirt thingy. Sorry, dont have a pic to post.
07-04-2017, 08:54 PM
I think I found a good option i will investigate more...Camping World has an item# 37764 that uses the on-board low pressure propane connector.
07-04-2017, 09:15 PM
X2
I did the same thing with my Coleman Road Trip grill...
now I grill under the awning using camper propane...
2014 Shamrock 183
07-05-2017, 07:43 AM
I will look later today. Thanks
07-05-2017, 08:00 AM
When we purchased our TT, we requested that the dealer swap out the RVQ for a stove. He did, and what we got was a 3 burner Suburban cooktop in a blow molded base that hooks on to the siderail and connects to the lp quick connect. I've seen the 2 burner style as well. I assume they're out of a FR PUP. I'd give either a 5 star rating. The 2 burner will be easier to stow away. 3 burner more cooking area. Way more useful than a grill hanging on the side IMHO, besides I'm kinda fond of the Weber Q with the direct hookup
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
07-05-2017, 09:00 AM
Found it. I should have seen label on side of trailer.
07-05-2017, 09:21 AM
We have a Camp Chef Weekender and bought the RV hose, which attaches to the quick connect. It has two 20 000 burners and legs, but they're short, so we use it on a table. It's incredibly powerful and just the right size.
07-29-2017, 09:27 AM
I purchased a CAMPCO grill. I comes with a quick disconnect hose.
07-29-2017, 10:38 AM
Always Learning
I'm modifying my Weber Q in the next couple of days with this Converta-Q kit from Torjik. It'll let me run my Weber Q from the low pressure port on the camper.
