Old 04-02-2011, 05:15 PM   #1
Question for SV-264 owners
Hi Folks I m visiting a friend and do not have time to search right now. can 264 owners please answer a few simple questions ?
Obviously 264 has two grey tanks, Does it have both gray tank and the blank tank dump valve at the same place like a regular TT or one grey tank is combined with the black tank and the other grey tank has its own valve somewhere else ?
can you access the bathroom with the slide in ?
The storage under the bed is fully available and is not occupied by FW tank or anything else ? If you could also specify when you answer the model year of your unit, they are looking at the 2012 units.
Thanks a ton !
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 04-02-2011, 06:08 PM   #2
Send a message via MSN to twalk47
I just brought home a 2011 264. The black and bath grey has the normal combo setup with two valves and commom outlet. The galley grey has separate outlet and valve at the front. You can get into the bath when the slide is in depending on waist size. I am37 in. and it is snug. Make damn sure you ck EVERYTHING out before you drive it off the lot. Hope this helps.
twalk47 is offline   Reply With Quote
Old 04-02-2011, 09:29 PM   #3
The storage under the bed is fully available in two sections. When the slide is in, you can open the door about 12". I have a 2011.
18267RBSS is offline   Reply With Quote
Old 04-03-2011, 01:27 PM   #4
Thanks for the replies ! I just went to my local dealer and checked (from outside) an SV-264 for my friends. Looks like the fresh water tank might be under the rear seat of the dinette ? is that the case or is it in the belly as it is seems to be the standard with all surveyors ? if someone can clarify that please ! Thanks
Old 04-03-2011, 07:12 PM   #5
Thanks to your help, my friends ended up with an SV-264 today !!!
We are the best forum for FR ever !
Old 04-03-2011, 07:26 PM   #6
Water is under floor.
Thurman Walker Colorado Springs,Co
2008 Toyota Tundra 5.7 Ltr
2011 surveyor 264
Old 04-03-2011, 09:00 PM   #7
Thanks ! They were at an RV show and that was the last point they wanted to make sure and checked it and signed the papers !
WHen we camp together now, there will be two Surveyors together ! Now I need to get him to be a member here
Old 04-04-2011, 12:09 PM   #8
OK, done! Thanks Goomph for your help, you helped me realize what I needed!
Thanks for the responses as well, it helped seal the deal.
I will be getting a 2012 SV 264, with the new Pull-Down TV cabinet (among some other goodies)! I saw the pics on the website, but it is not listed as an option yet or on the floorplan. I am excited!
SCOC is offline   Reply With Quote
