Old 06-10-2013, 04:30 PM   #11
Webfoot
Fixed!
I found a machine screw in my workbench that was the same diameter as the hole where the dowel was supposed to go in, so I screwed it into the hole and then cut it off with a Dremel.
The wood now just sits on the screw a bit and at first slipped over it if bounced lightly, so I ran a strip of double-stick tape across the bottom to keep it tight.
ID:	32845   Click image for larger version
ID:	32846   Click image for larger version
2012 Chevy Suburban 1500
2012 Surveyor SP-260
quackor is offline   Reply With Quote
