Old 09-12-2012, 09:39 PM   #1
mamentt's Avatar
Remove sofa for two chairs
Has anyone replaced their sofa in a SV264 with two chairs.
Questions:
1- Can the change be made by an non-master tech?
2- Can you use non rv chairs?
3- With the small width of the door, can the sofa come apart?
4- Is there a need to buy extra carpet for floor?
Any advice would be great.
mamentt is offline   Reply With Quote
Old 09-12-2012, 10:21 PM   #2
Twisty's Avatar
We've thought about doing the same thing.
I'm following this one.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 09-13-2012, 07:04 AM   #3
mike54's Avatar
we did couch went though the door on end I took the wood legs off.
The two recliners went in easier because the back and seat are not attached
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 09-13-2012, 08:27 AM   #4
Dave_Monica's Avatar
The problem is that the SV264 doesn't have a 'flush floor' slideout...the bottom of the couch is the bottom of the slideout to fit over the wheel well. I looked into the same idea when we had a Rockwood 2605 TT with a similar slide set-up. I couldn't come up with an idea to swap out the couch.
Dave
Old 09-13-2012, 08:44 AM   #5
TURBS's Avatar
Dave
If you used flush mount carriage bolts ran up through the bottom wouldn't that work?
Turbs
Old 09-13-2012, 09:11 AM   #6
Turbs
No...the problem is that the bottom of the slide is about 13-14" above the floor of the camper when it's pulled in.
Look at the non-door side exterior picture and you'll see what I mean about the height of the slide.
* 2013 Surveyor Select 264 New * * Couch's RV Nation
Dave
Old 09-13-2012, 09:19 AM   #7
TURBS's Avatar
Dave
Hmmm yes I see.
Old 09-13-2012, 03:19 PM   #8
mamentt's Avatar
I have a 2010 year model. Is there a difference in the slides?
Old 09-13-2012, 07:11 PM   #9
It's real easy to tell looking at the slide from the outside. Some of FR campers are lower to the ground so the wheel well extends above the floor surface. They hide the one side usually under the dinette and the other side under the couch which then requires that style of slide.
If I was able to change out the sofa in our Rockwood 2605 TT with recliners, I would have probably kept it longer. Unfortunately that's the negative of that stye of slideout.
Dave
Old 09-15-2012, 01:23 PM   #10
mamentt's Avatar
I got a chance to look under the sofa today, and you are correct it is part of the slide-out. (darn). May need to trade for another TT.
