Old 02-02-2013, 11:38 PM   #11
Oklahoma Proud
MillerTime's Avatar
this kind of stuff would definantly be the downside to working in a rv service department!
Old 02-03-2013, 06:18 AM   #12
Just wondering if my TT that have the underbelly covered do they put some type of insulation in there? If so what type of insulation?
Thanks,
John
2012 F150 ecoboost crew cab, 157WB, 3.73 rear axle,max tow & heavy duty payload
2012 Surveyor 305
2012 Nights Camped 50
2013 nights camped 27
2014 nights camped
BigJohn2 is offline   Reply With Quote
Old 02-03-2013, 08:00 AM   #13
Oklahoma Proud
MillerTime's Avatar
Thanks,
John
I can't speak for every trailer, but I have not seen one yet that had extra insulation behind the underbelly cover.
Old 02-03-2013, 04:01 PM   #14
Can't speak for all of them , but my Jayco Designer had pink fiberglass insulation . The entire bottom was insulated . Jim
FarmerJim is offline   Reply With Quote
Old 02-03-2013, 05:10 PM   #15
My KZ had yellow fiberglass plus the Coroplass cover. Youroo!!
Old 02-03-2013, 05:18 PM   #16
Our KZ had yellow fiberglass plus the Coroplass cover. Youroo!!
Old 02-03-2013, 08:42 PM   #17
VinceU's Avatar
Thanks,
John
Probably not, the insul is in the floor, floorboard, foam and outer luan sandwiched together. Bored a 6" hole in mine, its a total of 51/2" thick about 80% styrofoam. The pan will serve as a dead space, retarding outside air from reaching the cabin. Ever sit in a underway vehicle and touch the floor and tranny tunnel. It can get quite warm at high sustained speed, all due to friction and turbulence. The mfg. didn't install the pan for free, Engineering, fab and install costs money, yours, why throw it away?
Just wondering....
Old 02-05-2013, 09:25 PM   #18
Twisty's Avatar
"It kind of bugs the H#$l out of me thinking about gas lines or water lines or wires or connections or tanks or nuts or bolts or brackets that are loose or leaking or getting chaffed or worn or missing parts or..."
If this tank leaked or failed I could replace it myself w/o the hassle of having an unknown amount of sewage laying on the skin. Same with gray water problems. Also, the moisture is being held in against the frame and the floor materials. Why would I want my floor to be soaked in urine or ...?
If my brakes are acting up I could easily check for many simple problems or fixes.
Same with lights.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 02-06-2013, 06:34 AM   #19
ok, thanks. I will have to look and see if I have any under my Surveyor 305. Wonder how much this spry in Foam installation weights? Spray Foam Insulation | Home Insulation | RetroFoam™
Later,
John
2012 Surveyor 305
2014 nights camped
Old 02-07-2013, 08:28 PM   #20
VinceU's Avatar
Later,
John
Two Depots and one Lowes full, easy on very difficult off!
underbelly
