Old 05-24-2011, 09:44 PM   #1
Roof vents
I have a 2004 sv291 two of my vents have come loose from the inside ceiling on one corner. Does anyone know if they screw into the vent frame or just into the ceiling itself?
little joe is offline   Reply With Quote
Old 05-30-2011, 09:53 AM   #2
acadianbob's Avatar
Vent frame. Don't go into your ceiling!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 05-30-2011, 10:21 AM   #3
What is wrong with going into the ceiling ? First hand experience of a disaster caused by it ?
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 05-31-2011, 04:50 PM   #4
acadianbob's Avatar
Perhaps I misread the post. I thought he was talking about a "Max Air" kind of thing on top of the roof. As I read it again, he may very well have been talking about the standard roof vent. The ceiling from inside may very well be OK as long as the roof is not pierced. That's what I was trying to help him avoid.
b
Old 05-31-2011, 07:01 PM   #5
MOD Guy's Avatar
The inside plastic trim is screwed into the ceiling material (short screws) if one has come loose and will not stay tight, you can put a small, plastic hollow wall anchor in the hole. You could also squeeze a small amount of adhesive caulk into the hole, and then put the screw back in.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 05-31-2011, 08:07 PM   #6
sherdep's Avatar
I like using tooth picks to fill the gap when screws tend to stop fitting or come loose
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-01-2011, 08:10 AM   #7
Pictures, we want pictures So that we know what is exactly involved ..
Old 06-01-2011, 07:11 PM   #8
MOD Guy's Avatar
This method will work for solid wood, but the celiling panels are usually only 1/8" - 1/4" thick, so there is not much to grab on to.
High Springs, FL.
