Old 08-28-2014, 05:42 PM   #1
SC226 outside TV connection
I will be at a campground that does not have cable hookup so I will have to use the antenna for local channels. I want to watch the football games outside. If I connect to the outside cable outlet will that allow the me to have the outside TV on the antenna?
JBurley is offline   Reply With Quote
Old 09-12-2014, 06:04 PM   #2
There should be an outside antenna outlet. If you only have one outside connection, its probably for the antenna. Have you tried it?
Mad Dog 7.62 is offline   Reply With Quote
Old 09-12-2014, 06:49 PM   #3
Yes. Push in the button to power the antenna and then do a channel search on the TV. I do it all the time.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 09-13-2014, 03:35 PM   #4
I got it figured out!Click image for larger version
Name:	ImageUploadedByForest River Forums1410640497.649546.jpg
Old 09-13-2014, 03:39 PM   #5
JBurley,
If in the future you want to upgrade the TV mount here is what I did.
Replaced the TV with a 40 inch and installed a swivel locking bracket.
Name:	ImageUploadedByForest River Forums1410640655.508464.jpg
Name:	ImageUploadedByForest River Forums1410640670.197881.jpg
I then installed the existing bracket outside by the connections.
Name:	ImageUploadedByForest River Forums1410640761.562843.jpg
Now I use the jensen outside.
Old 09-15-2014, 02:34 PM   #6
JWedell:
I have the swivel TV in my unit. How did you attach the outside bracket to the trailer?
Old 09-15-2014, 02:44 PM   #7
I used the bracket that was inside and installed a new one
Old 09-15-2014, 10:24 PM   #8
Tooljunke's Avatar
How do you haul and store the extra tv without damage ?
2004 Dodge Ram 1500
2015 Forest River Surveyor 264 rks
Tooljunke is offline   Reply With Quote
Old 09-16-2014, 12:05 PM   #9
I am reworking the under bed storage to Put in a hamper with storage and a spot to store the TV. Or I may store it in the sofa draw I made.
Old 09-16-2014, 12:06 PM   #10
Added the picture
Name:	ImageUploadedByForest River Forums1410887207.254194.jpg
