07-13-2014, 10:54 PM
sc226rbds shower leaking
Over the weekend we noticed when I got out of the shower there is water coming from a belly skin opening (spray foam) by the dump handles. Anyone else have this problem? Is it an easy fix? By the dealer of course should be a warranty issue.
09-24-2014, 09:47 PM
I had the same problem... Wish I knew the cause of this one
09-26-2014, 03:52 PM
Yes, our black water tank had broken free and leaked between the floors on the first trip out. So much for quality control. Dealer fixed. I hope for good.
09-26-2014, 06:15 PM
Were you traveling with the black tank full?
Started Out With Nothing,
Still Have Most Of It Left!
09-27-2014, 05:32 AM
Check the drain and trap underneath the shower, and the putty seal at the drain. Fittings could be loose, shower floor flexing allows movement, you may need to add wooden blocks to stiffen the floor.
there should be a vent or access to see under there
that fixed my problem which was similar
09-27-2014, 07:07 AM
Mine leaked at one time....it was the shower valve leaking dripping down the pex tubing and leaking out the bottom. 20 bucks later.....and 20 minutes.....new shower valve and no leaks.
09-27-2014, 07:00 PM
No, not full in fact empty. However, it is entirely possible that I may have to travel with it full if I stay where there is no dumping station in future.
09-28-2014, 09:37 PM
My under belly is covered and there is foam coming out. I don't see a trap door to check it but I am having water drip from the foam insulation. Full disclosure it was the first time I had ever filled my fresh water tank but also my gray water got fu without me knowing and I found water standing in the shower. I drained some gray water out and at that point noticed a drip. Not sure if it's a fresh water problem or and over flow problem. But I will look closer for a way to see. My shower floor does flex being I'm a pretty good size guy.
10-03-2014, 10:20 PM
Leaking Shower
Mine goes in this next Thursday for some other warranty issues I will keep you posted on what they do to repair it.
Dennis
1973 Cuda 340 4 speed. All original
2014 Surveyor 226 RBDS
2004 Chevrolet 2500HD 6.0 ( Goldie)
10-06-2014, 09:02 AM
The trap frcamp was referring to is actually the shower trap found inside the trailer directly below the shower base. In my case there's a grill cover which when removed will reveal some furnace ducking and the shower drain connections.
If your set-up is similar look for some standing water that might help localize your leak.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS - 2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
10-06-2014, 04:33 PM
That makes sense. I do have a vent cover under my shower door. I will take a look. I towed wet this weekend to a BBQ contest and showered. Everything was dry. I feel my problem may have been the over flow of my gray water. One thing that I still don't understand. Do I have a galley tank? All I show a reading on my monitor is gray, fresh, black, and battery.. They galley is always empty which makes me think I don't have one.
02-13-2015, 09:05 AM
Gray water over flow shouldn't cause a leak. It will back up to lowest drain probably your shower. Doesn't explain water leaking under your floor.
02-13-2015, 09:47 AM
How many dump handles do you have under the unit? Should be 2 if you have gray, black, fresh and battery showing? You have to have a gray tank for sink and bathroom sink and shower.
Coachmen M/H
Concord
2018 / 300 DSC
02-13-2015, 02:22 PM
[QUOTE=frcamp;709096]Check the drain and trap underneath the shower, and the putty seal at the drain. Fittings could be loose, shower floor flexing allows movement, you may need to add wooden blocks to stiffen the floor.
X2 We had the same problem with our 220RBS. Leaking at the putty seal. Dealer fixed it under warranty. Safe travels.
2013 GMC Sierra 2500HD 6.0 Vortec
2014 Surveyor Sport SP220RBS
02-19-2015, 12:57 PM
Traveling Two
Just got our trailer out of the shop for the same reason. there was a leak in the P trap under the shower floor they fixed and no more problems
06-28-2015, 10:01 AM
I'm just closing the loop on this post. The repair shop tried to fix it but we had the same problem on my first trip out this year. I disassembled the floor drain and replaced the putty. Now no leaks!
thanks for everyone's help!
