Old 11-02-2012, 02:15 PM   #11
Originally Posted by ProjectPro View Post
I'm also having trouble keeping the end caps on the bumper, and am also using duct tape. Doesn't someone have a better way than either tape or the CW metal doors? The custom added tubes are very nice, but are way more than I need for our type of camping.
Drill a hole completely thru the bumper and cap and drop a rod or bolt down thru it.
Old 11-02-2012, 02:37 PM   #12
Witch Doctor's Avatar
After losing about 4 of them I did just as above I drilled a hole and inserted a bolt and wing nut. Problem over..
Old 11-02-2012, 02:54 PM   #13
3 Happy Campers's Avatar
Hereís how I dealt with the sewer hose issue.
$150 from Lippert
Lippert Sewer Hose Mgt System
Name:	Lippert Sewer Management System.jpg
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 11-02-2012, 03:48 PM   #14
Timex's Avatar
Originally Posted by rickthelen View Post
I have used a piece of black duck tape over the end caps. Leave the vent hole open. Been able to reuse tape half dozen times before needing a new piece. The black tape blend right in with the bumper and end cap
SEE, SEE, I'm not the only one that uses duck tape! Quack, Quack!
Timex is offline   Reply With Quote
Old 11-02-2012, 04:09 PM   #15
Terier's Avatar
I replaced my lost bumper caps with this type and 18 months later I haven't lost one yet. One per package.
I lost the original caps on the way home from the PDI.
Old 11-02-2012, 04:12 PM   #16
MtnGuy's Avatar
I guess I have just been lucky. The OEM plugs stay tight and in place.
Old 11-02-2012, 05:09 PM   #17
Another rat in the race
jar3316's Avatar
I just drilled a hole top and bottom then put a pin in. Used wire and made a "L" with just a little bend at the bottom to hold it in.
You can use the end caps on the brown and yellow hose to crate a seal and compress the hose. It won't hold forever but it will help putting it way. I put a chain link between the two end caps (the ones you can drill through without compromising the vacuum) and now you can pull on one and get the other out also, that with the compression I can fit both those and 1 of the Red style hoses.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
Old 11-02-2012, 05:18 PM   #18
TURBS's Avatar
You know there's a reason those come out right?
Old 11-02-2012, 05:23 PM   #19
jar3316's Avatar
Old 11-02-2012, 05:29 PM   #20
TURBS's Avatar
Originally Posted by jar3316
The bumper twisting and flexing causes them to wiggle out.
Spare tire will make the light weights do that.
