08-29-2012, 08:50 AM
Septic hose storage?
The folks we bought our 186SPT from indicated you could store the septic hose in the rear bumper--remove the rubber cap, put the hose in, and presto you're good to go...not. Upon arriving at the campground, both the bumper cap and hose were gone baby gone.
I think it's a terrific idea to store the hose in the bumper thereby placing whatever lingering odor may exist in the great outdoors, but is there a way to do it so that the hose remains in the bumper? If not, where and how do you folks store your hose so that odors remain contained and not waft up into the living area? Thanks!
08-29-2012, 08:53 AM
User dunnnc has a good method .
Pm him for a link or look in his profile albums
08-29-2012, 08:54 AM
RV parts stores sell plastic devices made just for that purpose. Do a google search for sewer hose carriers. BTW dont try attaching anything to that "bumper" or there will be more than your hose missing.
08-29-2012, 08:58 AM
CampingQueen
We purchased the brown hose with the yellow connectors available at walmart and we've also seen them at camping world, etc. Here's what I'm talking about : Camco 39625 RV Revolution Swivel RV Sewer Kit : Amazon.com : Automotive
The hose kit comes with two 10' lengths of pipe with quick connectors. It also comes with end caps for both ends of each piece of pipe.
I really like it because you can use just one section or connect to make longer pipe if needed. When it's time to pack up, we disconnect the hoses, put the caps on one end and then 'scrunch' the accordion pipe up and put the other cap on. The caps on are air tight so keep the pipe from expanding, which makes them nice compact lengths of pipe to store. With the caps on and it compacted you don't end up with the crazy huge length of hose snaking around, spewing 'left over' water at you when you are trying to store it or take it out for use.
With the caps on the end, there is absolutely no odor at all and we just store it in the passthrough storage in the original box it came in. (although I think I will invest in a plastic bin for it since the box is beginning to get a little worn out)
It will fit in the bumper too if you want to store it there, but you may have to file the little tabs on the ends down just a bit to make it easier to get in there. We don't bother because we have plenty of space underneath, the hose compacts so well and there is no odor with the ends capped.
Well worth the money, in my opinion. The only other thing I would recommend you get if you don't have already, is a clear elbow to connect between the dump valve (RV side) and the sewer hose. That lets you know when you are done dumping and also helps know when your black tank is clean when rinsing it.
08-29-2012, 09:04 AM
I have used a piece of black duck tape over the end caps. Leave the vent hole open. Been able to reuse tape half dozen times before needing a new piece. The black tape blend right in with the bumper and end cap
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Thanks Guys, actually going to Walmart today. Will use end caps and put all the septic gear in a separate box.
08-29-2012, 09:12 AM
The only problem with the ones the RV stores sell is they are too short for a 15' hose. I like to use the perforated 5" pvc from Lowes or HD and put screw in ends in both ends and strap them to the frame near the dump outlets. Out of the way and they don't have any smell.
08-29-2012, 09:04 PM
i bought 2 little hatch doors for the ends of my bumper, at CW.
been working great for the past 4 years.
08-29-2012, 09:10 PM
odor? i don't know about others, but i rinse my sewer hoses before i stow them in the carrier. . if i was hauling anything that had stench, i'd be a bull hauler in a kenworth .
11-02-2012, 01:30 PM
How do I keep the end caps in place?
I'm also having trouble keeping the end caps on the bumper, and am also using duct tape. Doesn't someone have a better way than either tape or the CW metal doors? The custom added tubes are very nice, but are way more than I need for our type of camping.
11-02-2012, 02:15 PM
Drill a hole completely thru the bumper and cap and drop a rod or bolt down thru it.
11-02-2012, 02:37 PM
After losing about 4 of them I did just as above I drilled a hole and inserted a bolt and wing nut. Problem over..
11-02-2012, 02:54 PM
Here’s how I dealt with the sewer hose issue.
$150 from Lippert
Lippert Sewer Hose Mgt System
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
11-02-2012, 03:48 PM
SEE, SEE, I'm not the only one that uses duck tape! Quack, Quack!
11-02-2012, 04:09 PM
I replaced my lost bumper caps with this type and 18 months later I haven't lost one yet. One per package.
I lost the original caps on the way home from the PDI.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
11-02-2012, 04:12 PM
I guess I have just been lucky. The OEM plugs stay tight and in place.
11-02-2012, 05:09 PM
Another rat in the race
I just drilled a hole top and bottom then put a pin in. Used wire and made a "L" with just a little bend at the bottom to hold it in.
You can use the end caps on the brown and yellow hose to crate a seal and compress the hose. It won't hold forever but it will help putting it way. I put a chain link between the two end caps (the ones you can drill through without compromising the vacuum) and now you can pull on one and get the other out also, that with the compression I can fit both those and 1 of the Red style hoses.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
11-02-2012, 05:18 PM
You know there's a reason those come out right?
11-02-2012, 05:23 PM
11-02-2012, 05:29 PM
Originally Posted by jar3316
The bumper twisting and flexing causes them to wiggle out.
Spare tire will make the light weights do that.
